rear end identification
Old Apr 4, 2011 | 07:00 AM
Vean555's Avatar
Vean555
I cant figure out what i have for a rear end. But the back plate is not removable. To get to the gears i have to unbolt the front cover. Does anybody kno what this is for a rear end.
Old Apr 4, 2011 | 07:27 AM
Tatt2biker's Avatar
Tatt2biker
? Dana 44
I would think it's a Dana 44 rear end, Look for the number 44 stamped on the right lower rear corner of the rear end, then look along the right axle tube stamped in the metal for the manufacturing date followed by the material number (6 digit number followed by a dash number). The axle model number will be cast in one of the webs and or on the nose of the axle.
Hope this helps
Frank
Old Apr 4, 2011 | 07:58 AM
Tatt2biker's Avatar
Tatt2biker
opps! sorry I see you have a F150 (100?) You may have a ford 9inch rear end, do you have any photos of the rear end?
Frank
Old Apr 4, 2011 | 10:13 AM
Poison Oil Racing's Avatar
Poison Oil Racing
it is a 9 inch
Old Apr 4, 2011 | 11:52 AM
Tatt2biker's Avatar
Tatt2biker
Thats what I thought when I re-read the post, as for the cover coming off from the front, ( ? ) not sure what he ment?
Frank
Old Apr 4, 2011 | 02:01 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If there is no inspection cover (on the backside of the housing), it's a 9" as this was the only rear axle w/o an inspection cover installed in 1957/83 F100's, 1975/86 F150's.
Cover coming off the front is a mis-nomer, because there isn't one. The carrier (aka pumpkin) bolts to the housing.
The carrier is what the OP is actually referring to.
Tatt2biker: The fact it's an F150 doesn't mean it only came a 9 inch.
1977/79 F100/150's: Ford installed Dana 44 rear axles in some of these trucks in an effort to improve fuel economy after the first Arab Oil Embargo ended in 1974.
The second Arab Oil Embargo occured in 1979.
Old Apr 4, 2011 | 04:48 PM
Vean555's Avatar
Vean555
thanks for the help. There is no stamp on this rear end that's why i was asking. I have to take the whole driveshaft assembly out to get to the gears. Its a pain in the ***.
Old Apr 4, 2011 | 05:42 PM
Tatt2biker's Avatar
Tatt2biker
Thks, Bill I didnt know they also came with Dana's 44. Thats why I love this forum you can learn something new everyday!
Frank
drumrunr16
1997 - 2003 F150
Nov 16, 2009 04:11 PM
mikefox670
1997 - 2003 F150
Apr 16, 2005 10:27 AM
brmkart14
Jun 11, 2004 11:14 PM
jambroson
Apr 2, 2004 12:46 PM
sharpshooter
13
Aug 3, 2003 08:02 PM
