Sponsored by: Auxito
rear end noise
Old Nov 15, 2009 | 07:14 PM
drumrunr16's Avatar
drumrunr16
rear end noise
I am told that this rear end noise probably means my rear end is going out on me. Anyone have any idea what it might cost to fix this?
Old Nov 15, 2009 | 09:13 PM
papajoemrt's Avatar
papajoemrt
your rearend going out could be many things?
seals, bearings, clutch packs in the LS, ring and pinion damage. A complete rear end job could get rather costly.
Old Nov 16, 2009 | 03:57 PM
fordf150farmer's Avatar
fordf150farmer
what kind of noise is your rear end making? mine is making a kind of humming noise, but it only does it under accelleration or constant power, but when coasting, it goes away. i have been told that it was just my u joints. we will see next week when i change them out and check my rear end.
Old Nov 16, 2009 | 04:11 PM
Bdox's Avatar
Bdox
Rear end noise can come from several different causes. Can you describe the noise any better? Does it change going around a right or left turn? Under load or under decelleration? Coasting?
Also is it a limited slip differential?
fordrulez
Apr 13, 2017 03:32 PM
tmyers921
Jun 14, 2016 01:14 PM
FarmerMaggott
Mar 1, 2016 11:05 PM
johnstonmatt77
Nov 17, 2015 02:19 PM
mullet283
1997 - 2003 F150
Apr 17, 2011 12:40 AM
