William, without a doubt mine uses the 3rd link Jim posted. Truck in my sig w/ D50. It can be had at any auto parts store. Look for the rounded hex spindle sockets. Should say 2 3/4" 6R.
Auto hubs use the 2 3/4" hex socket and manual hubs use the "four prong internal tooth" socket. I've had both sockets and they only cost about $20 each at Autozone.
Then you need the four prong socket. There will be a lock nut, lock washer, and retaining nut. If you have a chiltons manual it will tell you how to torque the nuts.
Just a heads up. The 95 parts truck I had with Warn manual hubs on te D50 used the same 2 3/4" rounded hex head socket. Had the exact same nut as my auto hubs. Doesn't mean it was correct but that's what was in there.
Somebody didn't read the Warn install instructions...
