radiator question
okay, well no leaking is good haha. i have 92 f150 nite edition. its a such a beautiful truck man. hardly and rust spots on the frame, none on the fender wells over the wheel, no frame rot whatsoever. i rear-ended somebody and need to replace my whole front end. new bumper, stone def., grille, headlights/parking, core support, air condit, cond., rad., and fan. when i got in the accident i almost cried hahaha its gettin there though and ill keep you updated on the brake situation
Just wondering, is this the one you're getting Vista-Pro Ready Rad 436009 - Vista-Pro Ready-Rad Radiators - Overview - SummitRacing.com ? If so, did you get it from Summit, or somewhere else?
i ordered it from summit. is there a problem with that or were you just wondering
Um, I was looking at the description of this rad and it states under "material" that this is made from aluminum and plastic.
You said your new rad was made of brass and copper.
Is that the right rad from Summit? I'm looking at replacing my rad also because one of the side tanks (plastic) is leaking and want a brass/copper one.
I found a 4 row Spectra Premium Radiator with the same part number 436009 at Auto Zone for $268.99 which has no plastic.
Do I need to worry about a different fan shroud?
Any thoughts?
CS45
Any thoughts?
CS45
carbs & chrome
06-24-2012 04:57 PM
