Does anyone make this?
Old Apr 4, 2011 | 08:11 PM
autobahn45's Avatar
autobahn45
bwilliams, if you don't acquire these before the show pm me and I can bring a few good used ones with me.
Old Apr 5, 2011 | 11:14 PM
RJP66F100's Avatar
RJP66F100
fits into boxes that are attached to the inner fender aprons at the top.
"fender apron"?? that's what i wear over my "fender skirt" when working in the kitchen
That's funny, yall know I don't work in the kitchen.
Old Apr 10, 2011 | 09:05 PM
RJP66F100's Avatar
RJP66F100
Tough crowd.....lol
Old Apr 11, 2011 | 05:05 PM
bwilliams7527's Avatar
bwilliams7527
Thanks for the info guys....Autobahn...I'll likely take you up on that offer.
Old Oct 10, 2011 | 09:37 PM
SoulsShadow's Avatar
SoulsShadow
Looking for parts
Hi everyone. I just bought a '66 F100 2WD styleside short box. The PO hacked together an air bag suspension that I'm trying to undo. I'm looking for driver and passenger side parts that are circled in the picture below. I appreciate any help. Thanks!
Old Oct 10, 2011 | 10:00 PM
99hosss's Avatar
99hosss
Hey partner, you can simply go to a pipe supply house and ask the counter for a pipe hanger cap for 1/2 or 3/4 pipe. they'll show you what will work for you. they look exactly original
Old Oct 11, 2011 | 08:01 AM
SoulsShadow
Which part is that a replacement for Hoss? I'm guessing the lower spring mount?
Old Oct 11, 2011 | 09:54 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Boss9F100
ND, That is complete MISINFORMATION! 5A306 IS IN FACT part of Frame.
Look at this parts catalog illustration you posted, it clearly shows the spring seats as SEPARATE PARTS.
I just noticed this, and yes you are correct about the location of the seats, but...
C6TZ-5A306-C .. Front Spring Upper Seat-R&L = 1965/72 F100 2WD / 1965/71 F250 2WD / 1972 F250 2WD before serial number M00,001.
C5TZ-5A307-A .. Front Spring Lower Seat-R&L = 1965/72 F100/250 2WD.
Old Oct 11, 2011 | 10:21 AM
Boss9F100's Avatar
Boss9F100
ND, Its so obvious to me you are absolutely clueless about a lot.
Just because is shows in pic does not mean it does not come with frame. Its a SERVICE part that means yes you can buy it separate but it comes with frame and is riveted on. In english so you can understand in case of a wreck or other the part is or should say was avail from ford. Back then if you bought a new frame it was part of it. For you to give WRONG info that the upper mount was on FENDER APRON is totally WRONG!
There you go again looking at a illustration in a catalog with NO understanding. Shame really all the misinformation you give out. You do help a lot I give you that but......surely clueless on a lot of stuff.
Old Oct 11, 2011 | 10:24 AM
Boss9F100's Avatar
Boss9F100
Please, when asking questions, list all the pertinent details.
Your "About Me" feature says 1966 F100. Is this 2WD or 4WD?
The coil springs do not mount to the frame. They sit on perches attached to the radius arms at the bottom, fits into boxes that are attached to the inner fender aprons at the top.
The shock absorbers fit thru the springs, attach to brackets that bolt to the radius arms at the bottom, with shouldered cups, rubber bushings and lock nuts above.
Where exactly are these supposed clips? EDIT: There is one rectanglar retainer per side (has two holes) in between the top of the coils, another pair at the bottom of the coils.
2WD is different than 4WD.
your quote
Old Oct 11, 2011 | 12:11 PM
NumberDummy
Uh huh, yeah, right. The pot calling the kettle black.
Yes, I agree...for some reason, looking at the pic, I assumed it was part of the fender apron, because unit-bodied Mustangs and etc had that set-up.
I did not say the spring seats didn't come with the frame, only that the catalog shows them as separate parts.
What other info have I listed that is wrong? I've typed 10's of 1000's of part numbers, name one number I've typed wrong.
I've decoded over 800 VIN's, Rating/Warranty Plates, Certification Labels...where is one error?
I typed 100's of posts inre to Ford history, name one that has wrong info.
Every time you spout off about me typing wrong info, I typed these same responses. How many times have you responded? Next to none, because you're full of it!
You shut your gopher trap because you cannot back up these wild accusations.
How many times have you found one error other than the above?
Frankly, I'm sick of arguing with peeps on this site. The battleship USS IOWA can't come here fast enough, because when it does, I've signed up as a volunteer. So you won't see me here on FTE very much...if at all.
And that's gonna p!ss off a lotta members and some of the high mucky-mucks that run this site, because I've helped 10's of 1000's of people with parts and VIN decodes. There was no one doing this before I joined.
How about you taking on this thankless .. PITA .. no pay job?
Old Oct 11, 2011 | 02:24 PM
66CustomCab's Avatar
66CustomCab
Not exactly thankless, ND. Tons of people, including myself, have thanked you for your efforts in this forum.
Old Oct 11, 2011 | 04:34 PM
  #28
Boss9F100's Avatar
Boss9F100
ND, refer to my above post. You claimed the upper spring went to apron which it does not. You also claimed the shock went inside of coil spring which it does not. Thats what I was pointing out the misinformation you gave.
If you do not like the fact I pointed this out then have a fine trip on the USS IOWA! You were simply wrong and all I did was point it out.
Old Oct 11, 2011 | 04:53 PM
  #29
fabmandelux's Avatar
fabmandelux
Enough is enough! This thread is CLOSED.
DuallyNewt
Mar 1, 2018 05:39 PM
OliveDrab76
Oct 30, 2016 01:01 PM
jerryst
Sep 25, 2016 09:24 AM
lmarkie
1997 - 2003 F150
Jan 26, 2015 09:28 PM
alconk
Nov 28, 2008 11:41 PM
