Need some wiring harness help
Old Apr 1, 2011 | 09:28 PM
PITS's Avatar
PITS
Ok hive...especially all you wiring harness gurus or at least someone with a service manual.
I am trying to hook up my radar detector as this truck goes way too fast. I mounted it on left most section of the dash near the riser. I ran the cable down to under the dash and was looking for someplace to tie it in. I noticed about a dozen wires that are dead-ended and taped up to the wiring harness that passes through the firewall between the e-brake and the steering column (see pic). Don't have a clue what these are for. I want a "hot when engine on" wire so the radar detector shuts down with the truck.
Can someone tell me what these wires are for, are they fused, and is there one I can use without messing anything up? Color code?
Thanks.
Old Apr 1, 2011 | 09:32 PM
Brian Uhlenhake's Avatar
Brian Uhlenhake
I wired my Valentine 1 to a fuse that powered up with key on.
Old Apr 1, 2011 | 09:46 PM
MisterCMK's Avatar
MisterCMK
How about this?
Ignition Hot-in-RUN Circuit no. CDC64 Wire Color: Yellow/Orange (early build vehicles White/Blue)
• A fused 5 amp circuit.
• Found: in cab under driver's side instrument panel near engine bulkhead
Old Apr 1, 2011 | 11:22 PM
lakedweller's Avatar
lakedweller
Time to get a multimeter, easy to test each wire to determine voltage, when it is hot, etc...
Looks like you need the in dash switch option..
Good luck
Old Apr 1, 2011 | 11:46 PM
Shepardsonp's Avatar
Shepardsonp
When i do mine, I run it to a fuse box and use a little clip that protrudes out from a "keyed" fuse and i am done with it. They cost about $.10 at most automotive stores. 10 minute job.
Old Apr 1, 2011 | 11:55 PM
mhoefer's Avatar
mhoefer
Askyour electrical supply for "fuse taps". Pick the radio or other such curcuit. Other alternative is upfitter switxh 3 or 4, lower amp curcuit. I use 4 switch for ipod chargeing, going to power 3 to run sat radio.
Old Apr 2, 2011 | 06:18 AM
TheKid1's Avatar
TheKid1
Why bother?...Once you get 'lit up', the LEO has your speed, with laser anyway...
Old Apr 2, 2011 | 10:44 AM
Marauder92V's Avatar
Marauder92V
Those are the upfitter leads. I am sending this on a mobile device and can't search easily. Search the forum for the body builder document. Might be in the sticky posts.
Old Apr 2, 2011 | 11:33 AM
PITS's Avatar
PITS
Because my Passport pays for itself a least once a week. Driving without it is like driving naked. Not too much laser around here but it has saved me countless times from that too.
I don't speed most of the time but I do like to know where the popo is. Its the 5 over tickets that I hate the most.
Old Apr 2, 2011 | 11:34 AM
MisterCMK's Avatar
MisterCMK
My post was taken from the body builders guide.
slipry14
Jun 22, 2017 01:04 PM
johnnich33
Dec 14, 2016 10:50 AM
spdljohn
Aug 29, 2010 11:17 AM
the Goat
Nov 2, 2007 01:29 PM
mcne2026
Jan 10, 2006 01:24 AM
