Sponsored by: Real Truck
Switched Hot Wire
Old Aug 28, 2010 | 07:24 PM
spdljohn's Avatar
spdljohn
Switched Hot Wire
I am hard wiring my radar detector in my 2011 f250. I need a "switched" 12 v wire under the dash so my detector will turn on and off with the ignition. Any suggestions?
Old Aug 29, 2010 | 10:27 AM
senix's Avatar
senix
Did you get the upfitter switches? Use of those. Probably # 4. I think it is a 10 amp.
Old Aug 29, 2010 | 11:17 AM
rotun's Avatar
rotun
Reads ***** rules!
Check the CJB (main fuse block), usually there are open terminals you can tap into off the back and a female spade connector will slide right in.
johnnich33
Dec 14, 2016 10:50 AM
PasoF450
6.7L Power Stroke Diesel
Dec 1, 2016 10:45 PM
TXtinct
Oct 4, 2011 08:50 AM
the Goat
Nov 2, 2007 01:29 PM
mcne2026
Jan 10, 2006 01:24 AM
