My -03 expy started to jerk when going into drive, when shifting into drive nothing happens till you give it about a 1/4 pedel then it takes off with a jerk and chirps the tires. but works ok going into reverce. if you stop and start again in drive its ok. it will only do it when shifting into drive.............tanks
my wife had the oil changed about a week ago, so i checked tranny oil and it looks good and smells good but they overfilled it. a friend of mine said it had to do with abs not working. I just drove it and there is no abs working going forward,but it works fine in reverse.
You would think so, but as odd as it sounds the answer is no. Internally there is more involved when shifting into drive than reverse. This naturally means more fluid pressure is required for drive than reverse. The TC can move enough fluid to meet the reverse demand without meeting the drive demand.
