I recently put in a new motor. I haven't even put 2000 miles on it yet. I think I loosened up something when I hit a big pothole. I get a vibration in the truck bad seemingly under my feet on drivers side. It only happens when turning left or even making a lane change to left. Also when going wot it seems to vibrate but not as bad. I looked at exhaust but everything seems tight. Any ideas?
When they put in my 5" exhaust 4 years ago there was some clamp that kept loosening and causing vibration. I think it was near the turbo. I had to go back 6 times to have it fixed. They never did replace the clamp just loctite it. I tried checking around turbo and don't see any thing loose. But maybe when resembling with the new motor that same clamp is loosening again?
