Bump bump bump bump
Old Mar 29, 2011 | 11:07 AM
Robert_Mays's Avatar
Robert_Mays
Bump bump bump bump
My truck has been hesitating off and on since I got it a few weeks ago but today it would hardly run 20mph. If it was a gasser I would swear the ignition was going on and off every half sec. I did manage to get it above 30 to try the cruise and eliminate the throttle pedal but that didnt change anything. It just did the same and the cruise light even blinked at me LOL I wish it would shoot a code at me but it hasnt yet. My thoughts are maybe CPS. I just changed fuel filter when I got it and could do it again but dont think thats it because it comes and goes and its too extreme of a jerk to be water in fuel. It literally bucks like a horse...Go for half sec/off for half sec. It doesnt cut off completely but if u are at anywhere but idle it does it. If I go back and try again now, it may run perfect the rest of the day. Hook a brother up!!!
Old Mar 29, 2011 | 11:14 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I would check the UVCH to make sure it is good and do the 50 cents mod.
Old Mar 29, 2011 | 11:20 AM
Robert_Mays
Will do....do you know a link to that? I would like to know the ohm specs
thanks
Old Mar 29, 2011 | 11:32 AM
tdpower's Avatar
tdpower
If your overdrive light was blinking you should have some codes stored in the pcm. What are you using to read codes? Generic obd2 code readers don't work on these trucks.
Old Mar 29, 2011 | 11:35 AM
Robert_Mays
Its a 6 speed and I have not tried to read any codes but the light has never come on
Old Mar 29, 2011 | 11:39 AM
DND58's Avatar
DND58
Did this just start since you bought the truck a few weeks ago, or was it that way when purchased? Tell us more about the truck. Any mods? Here's a link to check for open recalls on your truck. If it has the original CPS, it's free from Ford, then get another from Riffraff for a spare. Good luck.
Recall Information
Old Mar 29, 2011 | 11:42 AM
tdpower's Avatar
tdpower
So you have a manual transmission and the overdrive light on the dash blinks at times?
Old Mar 29, 2011 | 11:45 AM
Robert_Mays
I thought I noticed a slight stumble driving it home when I bought it but very faint if any. It has gotten worse the last week or so. Funny thing is, I pulled a boat about 100 miles the last time I drove it and it was perfect the whole time. Then this morning, I could hardly get it up to 30 to make the cruise come on to check and see if it was the pedal TPS. No mods on truck at all and I have a CPS coming from Ford in a few minutes. I have a wholesale acct with them so I thought I would throw one at it since my '95 I had before this one died from a CPS
Old Mar 29, 2011 | 11:46 AM
Robert_Mays
No, I have a manual trans, so no OD light to blink LOL
Old Mar 29, 2011 | 11:48 AM
miller_feed
Look at this thread. Post #2. https://www.ford-trucks.com/forums/8...ck-shakes.html
Old Mar 29, 2011 | 11:53 AM
Robert_Mays
Thanks, thats what I was looking for on the ohm readings. I assume just unplug the harness at VC and check from there through VCG to injectors? The only thing is, I have never gotten a SES light (Service Engine Soon)
Old Mar 29, 2011 | 12:36 PM
bulla's Avatar
bulla
Could it be fuel related. Might be why there are no codes!:-
Old Mar 29, 2011 | 03:41 PM
Robert_Mays
Put a CPS in it and so far so good.
Old Mar 29, 2011 | 06:34 PM
F350-6's Avatar
F350-6
If it happens again, watch to see if any other dash lights flash when it cuts off.
Old Mar 29, 2011 | 06:47 PM
big poppa's Avatar
big poppa
Opps sorry, mistaked the cruise light flicker for the OD button light.
