What Starter?
Old Mar 28, 2011 | 07:57 PM
MAULMAUL's Avatar
MAULMAUL
What Starter?
I just rebuilt the 460 for my 77' F150 and I was wondering what starters you guys recommended? It is a two wheel drive with a C6. I have Hedman elite headers and true dual exhaust running out the back.
Old Mar 29, 2011 | 05:54 AM
monsterbaby's Avatar
monsterbaby
stock starter will work just fine.
If it wasn't for the headers I would say you coudl also use one from a 92 or later F350 with a 7.5 as they are gear reduction but I wouldn't guarantee it would clear the header tubes.
I know NAPA even lists it for your exact application tho so easy enough to just go buy one.
I actually started my 13.4:1 compression 528cid stroker with a factory 400 starter when I broke the high dollar aftermarket one I had on the truck and had a race to go run.
Old Mar 31, 2011 | 09:12 PM
MAULMAUL's Avatar
MAULMAUL
Thank you. I sure do appreciate the help. Off to NAPA then. That will be much better than the $200 I thought I might have to cough up.
Old Apr 1, 2011 | 09:35 PM
PatsPOS's Avatar
PatsPOS
I'll back up monsterbaby on this one...I probably started my 10:1 compression breathed-on 460 a thousand times on the ORIGINAL '74 F-250 starter...and that would have been on a 25-to-30 year-old starter!
Pat
Mab1957
Oct 21, 2015 01:25 PM
1992FordF150Custom
13
Nov 6, 2013 06:54 PM
bob the viking
Jan 31, 2010 10:06 PM
DC_78
May 26, 2006 03:30 AM
Corbin18
1978 - 1996 Big Bronco
Aug 27, 2004 08:55 PM
