79 F150 Steering Column HELP!!!!
Old Mar 28, 2011 | 02:05 PM
WSU-Fordman's Avatar
WSU-Fordman
Hey guys,
I have my 79 F150 4X4 auto w/ tilt column, but my column broke. Dad threw the column out when we moved (GRRRRR.....), so I'm looking for some help.
I found a tilt for a 2wd, but don't know if they are the same as 4wd. Columnsgalore.com said the 2wd one would bolt right up.
Can I get a few more opinions before I go blow a few hundred bucks?
Thanks!
Old Mar 28, 2011 | 04:00 PM
Poison Oil Racing's Avatar
Poison Oil Racing
no, I don't believe it will work. 4wd shafts are generally shorter because the steering box is in a different location on the frame than a 2wd.
Old Mar 28, 2011 | 06:52 PM
WSU-Fordman
thats what i thought too. what if I had the tilt part but got a shaft from a 4wd? would the shaft from a straight column work?
Old Mar 28, 2011 | 07:42 PM
modrisco's Avatar
modrisco
Hi, all 78-79 truck and bronco tilt columns are the same. 2 wheel drive and 4 wheel drive. I have worked with these columns quite a bit. If you need any advice or parts send me an email. mitchod@shaw.ca
Mitch
Old Mar 28, 2011 | 09:03 PM
WSU-Fordman
Thanks Mitch. So i found one with for a 2wd for 200 bucks, the guys said it works perfect. It's the cheapest one I've found, but do you think I could find one cheaper?
Old Mar 29, 2011 | 08:29 PM
modrisco's Avatar
modrisco
I dont know what they go for down there but I find them in pick n pull yards up here for $40 . I see them on ebay for less than $200 but shipping can be a few bucks. If you are looking at one check the shift collar pin. They wear out and get sloppy. Check the lower bearing its in a plastic body and if bad they are difficult to find. Also check the tilt function for slop in the bearings and the pivot pins. If the pins are slopped out you have to change the main body if the bearings are loose or noisy they can be replaced. also check the signal light cancel function it is comon to find them broken. Make sure to get the dash trim with the tilt column as it is differnt than the regular one. Good luck.
Mitch
Old Apr 3, 2011 | 08:09 PM
WSU-Fordman
Got another question about these columns. Does it have to be an F150 column, or would a 250 work as well? thanks
ShoTym
Nov 5, 2011 10:05 PM
ford-nut
Feb 25, 2005 07:35 PM
