Bore?
Old Mar 17, 2003 | 04:06 PM
Ford_a_holic's Avatar
Ford_a_holic
Bore?
WHat is about the maximum you can bore out an engine? My guess is about 10%? Am I wrong? Whats a safe reliable rule of thumb.
Old Mar 17, 2003 | 04:29 PM
StrangeRanger's Avatar
StrangeRanger
Bore?
On most engines .030 before you start to sacrifice strength, rigidity or integrity. Some are higher but why push it?
Old Mar 17, 2003 | 07:48 PM
canzus's Avatar
canzus
Bore?
Depends on what you're going to use the engine for, 0.030"
would be my personal limit for the 302/5.0L for racing/towing,
while 0.040" over would be my limit for a mild street cruiser,
and yes, 0.010" can make all the difference in the world when
you're loading an engine heavily... bad things happen when the
block starts to deform, heads move, and intakes twist...
Old Mar 18, 2003 | 01:40 PM
georgedavila's Avatar
georgedavila
Bore?
Most shops bore up to .060 over without problems or sonic shecks.
351W strokers go to 4.150 bores (stock 4.00), 460s to 4.485 (stock 4.36).
If you're going to put some money in the engine, have the block sonic checked for about $70. That'll tell you the exact thickness of your cylinder walls top to bottom.
Old Mar 23, 2003 | 10:49 PM
broncr's Avatar
broncr
Bore?
I have heard that +.060 was the most a 300-6 would go. That was good for me 'cause my builder was already at +.040. Unless you're building a fire breather, going with the minimum ( usually whatever the machine shop says) gives you the POSSIBLE option of doing it again (and maybe again). There is nothing more comfortable than boring (or reboring) a block that has performed well for you for years and tens/hundreds of thousands of miles. You will know if you've taken care of it - something which is always a question with a junkyard block. I did bore a chebby 283 out +.120 one time (fire breather) it ran up to 8500 rpms off and on for about 35,000 miles (hotter engine=shorter life) but it was a kick while it lasted! My 300-6 (+.060) has 20k miles on a rebuild and is running like a top. I expect to get 150k+ from it.
Myfreeford
Aug 22, 2011 10:56 PM
wiles1947
Jul 19, 2006 01:08 AM
vulcan22255
Dec 15, 2004 11:53 AM
the_binbuilder
May 24, 2004 07:12 AM
bigblockhead
Mar 19, 2000 09:45 PM
