E40D shift problems
Old Mar 27, 2011 | 02:31 PM
blitzkrieg469's Avatar
blitzkrieg469
E40D shift problems
ok...93 F-350 4x4. 5.8 w/ e40d. won't shift to second until about 3500 or 4000 rpm. Then when it does finally shift...it acts like it goes straight to OD and skips 3rd. If I shift manually, it shifts a lot better. I've changed TPS, and adjusted MLPS. Truck has 180K on speedo. Just bought it so don't know if and when trans fluid and filter was ever changed. Any ideas would be appreciated.
Old Mar 27, 2011 | 02:55 PM
Hunt4Fun's Avatar
Hunt4Fun
Start with a complete fluid change and filter. The E4OD likes Mercon V best. My 93 had shudder and hard shifting until I changed the filter and had an entire fluid change done by using a T-Tech machine the lets the transmission do the pumping. Haven't had a problem since, over 18 months now.
Old Mar 27, 2011 | 03:35 PM
cj06's Avatar
cj06
also with 180,000 miles you should flush the cooler out and or put a separate external cooler on !
Old Mar 28, 2011 | 04:36 PM
blitzkrieg469
I read on another forum that you shouldn't use Mercon-V.....why?
Old Mar 28, 2011 | 07:31 PM
Nevada Al's Avatar
Nevada Al
From what I understand it has been reblended since it first came out around 10yrs or so ago,,,, Thats when it got its bad rep... Now it is THE Ford ATF..
Old May 2, 2011 | 04:50 PM
blitzkrieg469
ok...I changed the MLPS....done a trans flush(wich seemed to help).....and changed the TPS.....still haveing same problem......takes forever to shift to second.....if you drive real easy it shifts fine....if you manually shift it shifts fine.....if it shifts by itself, sometimes it shifts into 4th instead of 3rd....the only thing that pops inmy head is REBUILD!!!!!!
Old May 2, 2011 | 05:43 PM
cj06's Avatar
cj06
pressure test it !
Old May 2, 2011 | 05:48 PM
blitzkrieg469
sorry what do you mean pressure test it
Old May 13, 2011 | 08:41 AM
blitzkrieg469
ok...let me run this by everyone....I've changed TPS, MLPS, VSS (in rear diff), adjusted and readjust MLPS, adjusted shifter cable, did trans flush. ok....long sgifts from 1st to 2nd, then when it shifts again it sometimes goes to 4th (unless I have the OD turned off). If I shift it manually it will shift fine. If I start in 2nd, it seems to shift fine. If I disconnect battery and reset computer....if shifts great all by itself for about 15 min.....then goes right back to screwing up.....I don't have a cluse what to do next....any ideas?
Old May 13, 2011 | 10:08 AM
subford's Avatar
subford
Does not sound like a transmission problem.
The Transmission only shifts when it is told to by the PCM.
Was there any codes in that PCM before you disconnect it?
I put LED's in my cluster to see what my PCM is telling the transmission to do at all times.
If I were to guess I would say the PCM is bad from what you said about disconnecting the PCM.
Disconnecting the battery will have no effect on the Transmission.
But you could also have a bad Speed Control Module, RABS Module or PSOM.
Old May 13, 2011 | 10:21 AM
blitzkrieg469
On my way to pull codes....noticed speedo jumpin like crazy at 65-70ph
Old May 13, 2011 | 10:42 AM
subford's Avatar
subford
I would look at the PSOM then or the input voltage to it. It could also be a bad tone ring or bearings in the rear end.
Old May 13, 2011 | 10:45 AM
blitzkrieg469
Ok...thanks...let you know in awhile what i find
Old May 13, 2011 | 10:50 AM
subford's Avatar
subford
I meant to say bearings in the rear end not gears.
NOTE:
Only wiring harness end of connector is to be probed.
Connect Digital Volt-Ohmmeter to Pin 4 (speed in +) and Pin 5 (speed in -).
Does the voltage increase smoothly and continuously from 0 to approximately 3.5 volts AC as vehicle speed increases from 0 to 48 km/h (0 to 30 mph)?
Old May 13, 2011 | 01:46 PM
blitzkrieg469
ok...it pulled a code 62? and a 628 (TCC).
