Radiator Clarfication
Old Mar 27, 2011 | 03:37 PM
firestroker8706's Avatar
firestroker8706
Originally Posted by woodnthings
Have you looked into the thermostat sticking? That would cause it to get to that temp.
I actually just started researching that. I think I'm going to O'reilly later today and getting a knew one. Is the stock thermostat is 192 or 195?
Old Mar 27, 2011 | 03:38 PM
firestroker8706
Originally Posted by JOHN2001
I usually power wash mine threw the grill, if you go that route just be carefull. Your on the right track if there cramed with crap it may even lead to higher EGTs because a lack of air flow. Do you have gauges? If so what do you see on your EGT guage crusing around 60-70 empty?
EGT's are 800-900* at 60-70 mph. I have no idea if that's high or not. My 6.0 used to run 700* or less at that speed.
Old Mar 27, 2011 | 03:39 PM
JOHN2001's Avatar
JOHN2001
Not really. If the fluid gets to 225, you should get out of it and pull over to let it cool. With modern fluids, you can go higher than that but it is not recommended. 250* is when the factory gauge goes into the yellow.
He mentions 180* as hot and that is normal for all intense purposes. That is why I ask for clarification.
No pune intended, makes sense.
What were you doing to make the temps go up? Were you pulling a heavy load? What tune did you have your programmer in at the time? Gauges are a real must when running aftermarket tunes.
Old Mar 27, 2011 | 03:42 PM
JOHN2001's Avatar
JOHN2001
My EGTs are around 600* I have to think your high, if your running empty with 3:73 gears, 1100* is where you should back out of it empty to be EXTRA safe
Old Mar 27, 2011 | 03:45 PM
firestroker8706
I was in what they call the mileage tune, which is the first of 5 tunes. It was bone empty on the road back to colorado(where I lived at the time) from Texas. It was a fairly flat area with a few minor hills here and there, by no means terrain to test the limits of the truck.
The edge lets me watch up to 8 different parameters, but i've gotten to where I don't really trust it.
Old Mar 27, 2011 | 03:48 PM
firestroker8706
That's what I thought as well. I only saw 1100* once, and I was racing a ricer. I was puckered up tight while i did it too. I didn't like pushing my baby that hard, so i won't ever be doin that again.
I won, by the way.
Old Mar 27, 2011 | 03:52 PM
JOHN2001's Avatar
JOHN2001
I won, by the way.
I raced a probe with a fart can not too long ago and looked at my EGT guage and I hit 1600* I was scared for a minuite, lol hasnt happend sence.... I also won too
Old Mar 27, 2011 | 03:56 PM
JOHN2001's Avatar
JOHN2001
If you were driving normal theres something going on here, what was the outside air temp.? Do you have a factory trans. temp?, I dont, if you do does is coexsist with what programmer you have said as far as temp?
Old Mar 27, 2011 | 04:00 PM
firestroker8706
I feel like that's something you only do once before you start pushing your luck.
So, here's the list of things to do next weekend:
Radiator flush and fill with ELC
Clean the outside of the radiator
Install new thermostat
-What's the 203* thermostat purpose?
Run the heck out of it and hope the problem is fixed.
I think this is a good start, no?
Old Mar 27, 2011 | 04:02 PM
firestroker8706
I do have a factory trans temp, and the edge just reads what the OBDII port tells it. I can't quite remember the outside air temp, but it wasn't over 80*. it was march in colorado, it just doesn't get that hot there.
Old Mar 27, 2011 | 04:03 PM
Izzy351's Avatar
Izzy351
1100 isn't high at all. Aluminum melts around 1220F, so it'll run at 1100 all day long. I've buried my 1600 deg gauge many, many times. Just don't keep it there more than 20-30 seconds.....
Old Mar 27, 2011 | 04:08 PM
JOHN2001's Avatar
JOHN2001
Thats a good starting point. When International designed these engines whey were designed to have a 203* thermostat in them for some reason Ford decided not to put them in it. You cannot go down to Orilleys and buy a thermostat for these trucks they wont work, Im unclear 100% as to why because i dont rember, if you do a search in the thread youll find all the info youll need to change your thermostat. When I change a thermostat on anything I alwas have the wife boil a pot of water and drop the old thermostat into it to see if it opens in boiling water, and if it does that proably wasnt the problem but I change it anyways and put the old one in the glove box just incase I get stranded because of a thermostat.
Old Mar 27, 2011 | 04:12 PM
  #28
firestroker8706
That is extremely helpful info to know as I was just about to go get one. Do you know where to get one before next weekend?
Old Mar 27, 2011 | 04:14 PM
  #29
JOHN2001's Avatar
JOHN2001
At 60* outside and 60mph on the hwy my EGTs are just under 600* and trans. temp are roughly 120*
Old Mar 27, 2011 | 04:18 PM
  #30
JOHN2001's Avatar
JOHN2001
http://www.dieselsite.com/index.asp?...ROD&ProdID=186 I would check in other threads to find out where other people got theres from, if you want to get it before next weekend check the shipping. I think the one from dieselsite will work, ill look into in and you should do the same
