86 f150 problems
Mar 27, 2011 | 01:30 PM
86 f150 problems
I have a 1986 f150 i bought a few months ago, it will run and drive for about 2 mins then it will start bogging, and have no throttle response, ill hit the gas and about 5 seconds later ill get a response, it seems almost its shutting off and turning back on while im driving. Ive replaced both fuel pumps, the ecm, the inertia switch, tried advancing the timing, and the fuel filters. Any advice is appreciated thanks
Mar 27, 2011 | 03:36 PM
I am guessing this is a fuel injected 302? If so, I haven't seen where you pulled any codes from the computer.
Mar 27, 2011 | 10:31 PM
ya its a throttle body injected 302. ill try pulling some codes thanks
Mar 28, 2011 | 01:09 PM
This is not looking good from the start. Ford never installed a throttle body injected engine in a truck that I know of.
Mar 28, 2011 | 05:28 PM
Quote:
Originally Posted by
Franklin2
Its either fuel injected, or carbed. I'm sure they didn't use a throttle body on their trucks.
Mar 28, 2011 | 06:22 PM
my bad its just fuel injected i thought it was throttle body
Mar 28, 2011 | 06:30 PM
plugged, or partially plugged injector? I don't know too much about EFI. I'm a carb man myself.
Mar 28, 2011 | 09:58 PM
ya carbs are alot easier ive been thinking of just doing a carb swap ill try cleaning the incjector, thanks
