cab twisting....
Old Mar 26, 2011 | 10:25 PM
ColdForge's Avatar
ColdForge
cab twisting....
Ok well when i hit the gas the cab goes to the left hard and when i let go it goes back to the right. The axle stays going straight. I replaced my motor mounts last weekend thinking they were the cause but it still does it. i was thinking now that it might be the spring bushings. Becuase that is the only thing I can think of that is touching the cab. what do you guys think? o yeah i checked the cab mounts thier good.
82 6.9d single cab 4x4 standard
Old Mar 26, 2011 | 11:08 PM
Franklin2's Avatar
Franklin2
Look for cracks along the firewall. A guy I work with has a 89 diesel, and always heard this creaking noise when driving the truck. He went to put a later model frontend on it, and when he took the front clip off, that's when he discovered a long crack in the cowl area. His radiator support was also rusted out on the bottom around the radiator.
Another way you can check things is to get someone to pull up and down on the doors when they are opened wide, while you check around for movement.
Old Mar 26, 2011 | 11:10 PM
ColdForge's Avatar
ColdForge
ill check that out bc the truck came with a new radtior. so ill check to see if the old one was leaking
Old Mar 26, 2011 | 11:13 PM
ColdForge's Avatar
ColdForge
You know when drag racers have to much tourqe and teh front end comes up to the left well thats what it does but its just the cab not the axle and cab
Old Mar 26, 2011 | 11:19 PM
Franklin2's Avatar
Franklin2
The radiator support being rusted out is probably what cracked his cowl area, since the front of the cab was trying to support the whole frontend instead of the radiator support doing it's job. Coolant leaking does not rust it out, road salt is the main reason.
Old Mar 27, 2011 | 12:01 AM
84-6.9L's Avatar
84-6.9L
Especially with the manual trans check the cowl and firewall they were noted for cracking around the clutch master.
Old Mar 27, 2011 | 12:44 AM
ColdForge's Avatar
ColdForge
ok so i need to take off the front grill and the radtior to see this and its the the metel peice that connects the two side frames together?
Old Mar 27, 2011 | 12:46 AM
ColdForge's Avatar
ColdForge
and if so is this piece easy to replace?
Old Mar 27, 2011 | 01:13 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Also want to check for a broke/cracked frame rail.
Old Mar 27, 2011 | 01:22 AM
ColdForge's Avatar
ColdForge
i checked it out when i had it in the air when i was changing the MMs out. there still in good shape no rust for being in washington.
Old Mar 27, 2011 | 03:16 AM
Ken Blythen's Avatar
Ken Blythen
Are you sure that there definitely is a problem?
It's normal for the torque of the engine to cause the cab & chassis to twist when you punch the accelerator hard from an idle, & then to come back again......assuming this is parked in neutral.
The wheels & axle won't roll with the chassis because they are firm on the ground.
Old Mar 27, 2011 | 08:50 AM
ctubutis's Avatar
ctubutis
I have never seen such behavior on a truck and wouldn't consider it normal.
Assuming an automatic transmission here....
Have somebody sit inside, foot firmly on brake, tranny in Drive, hit the accelerator hard
while you investigate from underneath or from under the hood.
This should be easy to see (if you can see it from inside the cab, you can see it from
outside), throwing parts at it because you think they might be the cause is a waste of
time, money & labor.
Old Mar 27, 2011 | 08:57 AM
84-6.9L's Avatar
84-6.9L
Do you hear any clunking when it does? Unlike the gassers our diesels make all our tourque at around 1400to1600 rpm and with my trailer on i get some twist when pushing the smoke button, and in low range moving around the yard or pits loaded we really get some twist were my frame fells like rubber.
Old Mar 27, 2011 | 09:33 AM
Sw1tchfoot's Avatar
Sw1tchfoot
Check the cab mounts?
Old Mar 27, 2011 | 09:45 AM
84-6.9L's Avatar
84-6.9L
2x on the mounts and the bushings in them
