Sponsored by: Real Truck
Programmers
Old Mar 27, 2011 | 09:30 AM
GeneLaw1's Avatar
GeneLaw1
Programmers
Gene back, with an '06 F250 Lariat, 6.0 TD....Anyone ever use the programmers? Buddy of mine told me I should grab one to get the best gas mileage and/or performance. What are you guys' opinion on them? Always been my motto to leave well enough alone, but if they help, I would pull the trigger on one...
Cheers
Old Mar 27, 2011 | 12:48 PM
FI460's Avatar
FI460
I did see slightly improved mileage when I had one, but in my opinion it isn't worth the risk. To run a tuner on a 6.0l you need to have multiple gauges added, and ARP headstuds are almost a requirement. If you use the tuner smartly you can avoid issues, but it does raise your risk factor quite a bit. If you are happy with your truck as is, I would leave it that way.
Old Mar 27, 2011 | 12:52 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
Gene,
Recommend you go down to the 6.0 forum on this site and do some research on programmers. There are pros and cons and the cons can come with a hefty price tag. My second recommendation would be to learn about the strengths and weaknesses of your 6.0 first and then decide if a programmer is for you. However, there are some other things I'd recommend you get before a installing a programmer (upgraded exhaust, gauges (EGT, fuel pressure, at a minimum). Again, you'll find a lot of information about these items down in the 6.0 forum.
delano0512
Feb 23, 2013 10:58 AM
Dyllan78
Jan 16, 2011 09:52 PM
OptimusF150
2004 - 2008 F150
20
Aug 15, 2010 04:52 PM
mgd26
Alberta Chapter
Jul 6, 2009 12:00 AM
Shep VA
Modular V10 (6.8l)
Sep 27, 2007 10:49 PM
