Engine problems
Old Mar 26, 2011 | 10:49 PM
zlusmc's Avatar
zlusmc
Engine problems
Let me give y'all the rundown first. My truck broke down on me the other day. It cut off while I was driving down the highway. I noticed I wasn't getting fuel to the carb, so i replaced the pump. Upon further inspection I found that the distributor wasnt spinning. We pulled it out and looked at the camshaft and noticed it wasnt spinning when the engine was being cranked. I either have a broken timing gear or a broken camshaft. My problem is I don't have a FSM or anything to get in there and do this the right way. Can anyone direct me to write ups or FSM's or offer some input? I'd really appreciate it.
The truck is a 79 F100 with a 300I6.
Old Mar 26, 2011 | 11:32 PM
85e150's Avatar
85e150
Haynes or other find brands are available on line or in stores.
http://www.repairmanual.com/online/h...manual-h36054/
You MAY luck out and find the plastic gear has just worn or broken and a new timing gear set is all you need. Some report trouble getting those gears off, but you'll have to try it to find out with yours.
4.9L/300 - FORD - Timing Gears - Cloyes Gear - SummitRacing.com
If it's worse than that, like a broken cam, imo it's time for a rebuild, as you'll want to take the engine apart and get all the metal out of it anyway. The plastic parts are bad enough, and sometimes plug the oil pump pickup, so you may be in for more fun anyway.
Old Mar 27, 2011 | 11:41 AM
clindahl's Avatar
clindahl
I would recommend going ahead and taking the front timing cover off and see if the timing setup is broken or not.
89lilfoot
Nov 7, 2011 01:59 PM
bluneon
Aug 12, 2009 05:05 PM
bluneon
Aug 14, 2006 03:41 PM
carpe_diem
Oct 24, 2003 11:22 AM
carpe_diem
25
Sep 25, 2003 11:21 PM
