I just bought a 1978 F100 off the original owner, I'm trying to restore the truck back to as factory original as possible. Does anyone have any pictures of the F100 with a 302 from the factory so I can use it for reference purposes, for wire harness, vacuum lines, all components etc. as many detailed pictures as possible please.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
I can take some and post them but how close up do you need them to be. One more thing is the motor out of the truck or did they take stuff off of it. Anyway I'll try to get you what you need. Scott
No the engine is in the truck, there was a bunch of aftermarket crap like a cruise control and other stuff, so the vacuum lines were cut everywhere, and there is some extra vacuum equipment that I'm not sure is factory stuff or aftermarket for the cruise control. So I'm looking for factory original engines so I can see what the engine is "supposed" to look like so I can re-run the vacuum lines, wire's, ect the way they were out of the factory. So if you can help please post as many and as detailed pictures as you can!!
