help im stuck between the two
Old Mar 26, 2011 | 07:26 PM
grizzly11's Avatar
grizzly11
I have had my mine set on a chip ever since my OBS truck that i had. I recently picked up a 01 at the end of October with 187,??? on it that apprently had a bad motor so i got it real cheap. Did the work Myself and have since almost put 10,000 miles since. Dont ask were i went bc i cant tell ya haha. I am dead set on getting a php fu chip but am parenoid about smokin my trans. I also am aware that it could last if im responsible with it. Currently in the last couple months the trans runs about 110 around home and 110-120 on the expressway (75mph). Should i spend the money on the 6637 kit through clay or get a transgo tugger kit? I already have guages, zoodad mod (noticed a big difference), exhaust, mods. im just tore between the filter or shift kit.
thanks
jared
Old Mar 26, 2011 | 08:18 PM
JOHN2001's Avatar
JOHN2001
IMO, I would go with the shift kit, If you pull a lot and are scared of heat for your trans put a 6.0 trans cooler in it. Try not to exceed 100* ambient air temp., and you should be ok. With the 6637 you can buy the filter and get a piece of 4'' conduit like I did and be done with it
Old Mar 26, 2011 | 11:45 PM
grizzly11's Avatar
grizzly11
I don't do any towing but will if I have to do you think that if I only use the 120 or 140 for a race the trans will hold up if im careful what is a good price on a tugger kit and how hard is it to put in
Old Mar 26, 2011 | 11:57 PM
JOHN2001's Avatar
JOHN2001
$237.50 I believe is how much a John Wood valve body is. I have both of those tunes for 6 month and so sign of any problems yet. All I use those for is to race. The 6637 is cheap compaired to the tugger kit. I dont have a shift kit and mine seems to be holding up fine, shifts a little sloppy when Im getting on it. I dont know how hard it is to put in though, Im no help with that sorry.
You can make your own Tymar intake for cheap, you can use a piece of PVC with an outside diameter of 4'' about 4-6'' long, get the filter and youll need to get one 4'' band clamp and your intake is done. youll also have to cut up your factory air box to make it work and if you want to make a cold air box you can do this
https://www.ford-trucks.com/forums/1...-6637-cai.html I just got done making mine it cost about $30. I still have to paint it and install it.
Old Mar 27, 2011 | 12:01 AM
JOHN2001's Avatar
JOHN2001
I dont know what your budget is but you can do the Tymar for around $65 give or take
You can do the CAI box for around $30.
I dont know the exact numbers on the shift kit, maybe someone else will chime in on it, if you dont do any pulling then do the 6637 and box, some say it doesnt make a difference just like the zoodad doesnt do anything either, its all personal opinion, but its one more thing you can say youve done.
Old Mar 27, 2011 | 12:12 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Riffraff Diesel: John Wood 4R100 Valve Body
Riffraff Diesel: 6637
Let me know if you have any questions.
Old Mar 27, 2011 | 01:18 PM
JOHN2001's Avatar
JOHN2001
Awesome, thanks for posting Clay. I knew I was close on the numbers.
Old Mar 27, 2011 | 05:57 PM
grizzly11's Avatar
grizzly11
ok well i think im gunna go with the intake and add the tugger later in the summer i have already started a cai for the 6637 for a metal shop project. My teacher wants it done so she can take it to a state competion so it should be done at the end of the week hopfully
Old Mar 27, 2011 | 06:00 PM
JOHN2001's Avatar
JOHN2001
Good luck and post a picture when your done so you can brag about it
Old Mar 27, 2011 | 06:22 PM
Izzy351's Avatar
Izzy351
The Tugger runs around $100, depending on where you get it... It's an excellent mod. Love what it did to mine.
Old Mar 27, 2011 | 06:26 PM
JOHN2001's Avatar
JOHN2001
Izzy you pop in on almost every thread Im in lol.
I cant wait to put a Tugger on my truck
Old Mar 27, 2011 | 06:28 PM
grizzly11's Avatar
grizzly11
I will post pics when done if i can get it to work and what do you guys think about painting it with some high temp paint or some kind of ceramic coating to keep the heat out?
Old Mar 27, 2011 | 06:35 PM
JOHN2001's Avatar
JOHN2001
Paint it but dont waste your time with any high temp. paint its not gonna do you any good. Save your money and get a piece of rubber to put across the top of the box to seal it to the hood
Old Mar 27, 2011 | 06:47 PM
grizzly11's Avatar
grizzly11
ok will do im thinking about black with a red cover on the filter. Any opinions and for rubber would some flexable hose with a cut in the center and slide in on the top edge
Old Mar 27, 2011 | 06:54 PM
JOHN2001's Avatar
JOHN2001
Im gonna paint mine black and I already have a black cover from Clay. That should do the trick, make sure its thick enough to hold up for a long time but thin enough to flex. I still havent gotten my box painted... Its on the back burner, but I did pain the turbo housing today and Ill finish it tomorrow
