Engine noise
Old Mar 29, 2011 | 02:10 PM
Kwikkordead's Avatar
Kwikkordead
Originally Posted by homesteader
Yeh I wanted to a compression test just to check the condition of engine. That truck was in an accident so the only thing I got left is trans and motor. I sold the rest of the good parts. That engine could be going in another truck. So it will go on a stand, change some parts and into that truck. Is there a wiring harness just for the glow plugs? Or do I have to replace the injector and Glow plug harness?
Thanks
The injector and glow plug harness are combined into one unit under the valve cover.
But you should see that already, you have the valve cover off.
Old Mar 29, 2011 | 02:45 PM
big poppa's Avatar
big poppa
Glad it wasn't anything major, reps for the internal and external vids..
Old Mar 29, 2011 | 04:56 PM
homesteader's Avatar
homesteader
The only thing that bugs me is that I can't find that piece that the connector pushes onto that supposed to be on the top of the glow plug.
Old Mar 31, 2011 | 02:22 AM
homesteader
Well I pulled the glow plug the other day and found a little hole in it. Today I pulled the rest to check physical condition. Here is some pics.
In this pic you can see the bad glow plug with the hole in it. Also see the difference in color.
Here is another. Why is the body different color? Still cant figure out what happen to the top piece of the bad glow plug.
Old Mar 31, 2011 | 07:43 AM
Kwikkordead
The bad glow plug is discolored because it had all that combustion heat blowing up through it.
You are very fortunate for the fact that the tip didn't break off and get knocked around inside the combustion chamber.
It would have damaged the piston crown pretty badly.
Old Mar 31, 2011 | 11:35 AM
homesteader
Okay thanks Dan. Is that why there was a lot of carbon build up on the body of the glow plug ?. I had to use some brake clean to work it out.
Can the glow plug be tested out of the engine?
grimtech
13
Jan 26, 2015 08:21 PM
rwcmick
Mar 27, 2011 04:20 PM
BlueOvalBud
25
Jan 23, 2011 07:25 AM
i eat hybrids
Modular V10 (6.8l)
Apr 12, 2008 02:25 PM
markjw
Aug 15, 2005 08:58 AM
