Name this tube???
Old Mar 26, 2011 | 02:37 PM
F-250 Super Duty's Avatar
F-250 Super Duty
Name this tube???
While replcing another CPS today I looked up and saw this tube. Not sure if it's some sort of vent or what, but the light must have been just right to see it. Never noticed it before. Has some oily residue on it which is what was leading me to believe it is some sort of vent. Somebody set me straight.
Old Mar 26, 2011 | 02:42 PM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
Looks like the drain tube for the fuel bowl.
Old Mar 26, 2011 | 02:43 PM
Izzy351's Avatar
Izzy351
Yep -- your fuel drain O-rings need replaced...
Old Mar 26, 2011 | 03:16 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Here is a link to the parts you need to replace the o-rings.
Replacement O-rings for Ford Diesel Engines
and instructions...
http://www.dieselorings.com/docs/FuelDrain.pdf
I added a length of fuel hose to that tube with a hose clamp so I can drain the fuel into a container (instead of all over my driveway...). The other end of my hose has a removable plug with a clip that secures it to the bottom of the radiator area. Seems to be a handy location for me.
Have you replaced your fuel filter yet? I think the recommended intervals are every 15k miles or so. I order my filters from RiffRaff but you can get them from Diesel0rings.com as well. If you are placing an order for the 0-rings....might as well get some filters as well. The price is way cheaper than the dealer btw.
Last word of caution....
Sometimes aftermarket fuel filters are purchased with the lid integrated as part of the filter. You will need the separate lid if you plan on using the OEM style filter that i listed above. If you don't have the OEM lid, then you can get one from the same site as well. Here is a link.
Hope this helps.
Old Mar 26, 2011 | 03:31 PM
F-250 Super Duty
Fuel bowl drain never crossed my mind, but makes perfect sense now that you pointed it out. Just one of those days you know....
