6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
DPF problems
Old Mar 25, 2011 | 07:44 PM
ryanam's Avatar
ryanam
DPF problems
Hey, so over the last week my dpf has gone into regen mode everytime I have driven the truck. I got curious today as to if I am leaking oil, and removed my boots of the pipes. I noticed oil and water (coolant i think, it was hard to smell over the strong smell of rotella oil) in the pipes and in the bottom of the intercooler. Is my egr going or my oil cooler? Has anyone else experienced a similar problem? Any help is greatly appreciated.
Old Mar 26, 2011 | 05:06 AM
senix's Avatar
senix
oil level? Degas bottle level? What about at your tail pipes? Anything there?
Look inside the air cleaner tube. What do you see there?
Sounds like maybe a EGR valve/cooler.
Old Mar 26, 2011 | 09:36 AM
ryanam's Avatar
ryanam
My oil level is just below the full mark. My degas bottle has coolant in it, it has gone down though. My tailpipe is still clean. There is a little bit of oil in the air cleaner tube leading to the turbocharger. I'm guessing this oil is from the crankcase breather. The weird part is all of this oil and coolant is before where the egr coolers meet the air intake. So it has me wondering if it could be a seal in one of my turbos as well.
Old Mar 26, 2011 | 01:14 PM
senix's Avatar
senix
EGR/Coolers I suspect. Get it pressure tested. Tell them all of the symtoms and coolant creep.
Old Mar 26, 2011 | 02:27 PM
slowmans's Avatar
slowmans
I would say the water could be from moisture build up in your intercooler, this is a common problem on the 6.4..and the oil is probably from your breather.
Old Mar 27, 2011 | 09:04 PM
ryanam's Avatar
ryanam
Hopefully that is all it is. It finally stopped regening today, and I threw my buddies car on my trailer to try to make the engine work and hopefully clean it out a bit. I'm going to take it to ford this week and have them look at it, see if im worrying about nothing.
Old Mar 28, 2011 | 04:34 AM
R-T0r21on's Avatar
R-T0r21on
It's normal, as Slowmans said. Be advised that with nothing for the dealer mechanic to "see" and no codes, they'll just send you on your way.
CISKOWSKI_21
18
Apr 20, 2020 07:54 PM
Boone87
Feb 28, 2017 01:38 PM
szpieleusa1
13
Feb 8, 2017 08:23 PM
Ford Hay Farmer
May 23, 2016 06:00 PM
sdcowman
Dec 16, 2011 07:51 PM
