2.9 compression
Old Mar 25, 2011 | 12:24 PM
pmibach's Avatar
pmibach
2.9 compression
i was just wondering what normal compression would be for a 2.9 with 120k and at what point would you think about a rebuild?
thanks
Old Mar 25, 2011 | 01:26 PM
Rangerman Stan's Avatar
Rangerman Stan
120K isn't that much when it comes to considering a rebuild unless it has some serious issues in the lower end. The 2.9 I had in my 90 Ranger had over 239k and was still going strong. Had severe body rust issues though. It also had the typical lifter tick, but wasn't real bad and it never got worse. Your compression readings should be around 120 psi or so. Even if the readings are lower it can be ok as long as they are pretty close for all 6. But, if you have one cylinder that's a lot lower than the others there are tests you can do to determine if it's a valve issue or piston ring issue. Is it giving you problems?
97 stroker
Bronco II
Mar 10, 2017 11:49 AM
rusty70f100
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
40
Jan 11, 2014 09:13 PM
Blown 331
Dec 24, 2009 04:57 PM
jackofalltrades
Bronco II
20
Sep 12, 2008 05:49 AM
piperig78
Sep 7, 2008 05:41 PM
