vin tag
Old Mar 25, 2011 | 12:37 AM
79str8six's Avatar
79str8six
vin tag
I cant seem to find VIN tag on frame. yes there is one on the door but Previous owner may have changed doors.
is it stamped or is there a tag?
1979 f250 4x4.....i think door says 78....this is just curiosity. not end of world if i dont find it.
Old Mar 25, 2011 | 01:04 AM
piperig78's Avatar
piperig78
VIN location on frame<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
one is on the right side frame rail around the alt. the other is under the cab by the back cab mount<o></o>
These are both on the passanger frame rail, and seem to be were everyone says they are. Got this off this site awhile ago.
Old Mar 25, 2011 | 01:06 AM
piperig78's Avatar
piperig78
They are stamped in the frame
Old Mar 25, 2011 | 01:14 AM
Sleepy445FE's Avatar
Sleepy445FE
Just like he said, passenger frame rail in those two locations. I've heard of a few not having the stamping around the alt. My doesn't for one. Takes a little work to get at the one under the cab. That's where I had to find mine though, took about an hr of work. I can tell you how to get to it with the cab on if you don't seem to have the other one.
Old Mar 25, 2011 | 08:20 AM
clovins's Avatar
clovins
The passenger frame rail is correct. FYI...on 4WD trucks the VIN tends to be stamped closer to the firewall next to the exhaust. On 2WD the VIN tend to be stamped below the alternator.
It's good practice to locate the VIN on the frame. If your title Vin doesn't match the frame VIN it can cause problems.
Old Mar 25, 2011 | 09:20 AM
Melbatoast's Avatar
Melbatoast
Mine is a 76 4X4 and the vin kisses the cab mount at the radiator. I think they were drunk when they built some of these trucks.
Old Mar 25, 2011 | 12:22 PM
D-mon's Avatar
D-mon
kinda of subject but not really.......
I have a 79 f-150 custom 4x4 i got the vin # and some other numbers but i am wondering what my paint color is?
The truck is green and the paint code from the door is "VR" and i looked on lmc truck parts magazine and there is no "VR"? Also on the door there is a bunch of other letters like a/c which there is no air cond. in the truck.
it goes.(bare with me) [mldg]intertrim]a/c]r]s]ax]tr]
] are lines anyone have an idea or place where i can look more stuff up
thanks guys!
Old Mar 25, 2011 | 07:24 PM
79str8six's Avatar
79str8six
thx guys i check it out
Old Mar 25, 2011 | 07:35 PM
mikeo0o0o0's Avatar
mikeo0o0o0
thanks guys!
I've seen this paint code before, I just can't believe someone would order a truck painted like this.
Code VR= (V) medium chestnut metallic (R) Light jade.
Maybe its just I have different tastes.
As for the other codes, these are off the metal warranty tag riveted to the drivers door? Those don't look familiar to me. Could you post a picture of the tag?
Here is what's normally on the drivers door.
Old Mar 25, 2011 | 07:44 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Also on the door there is a bunch of other letters like a/c which there is no air cond. in the truck. it goes.(bear with me) [mldg]intertrim]a/c]r]s]ax]tr]
This jazz makes no sense. See * below.
COLOR code VR: V = 1979 Medium Chestnut Metallic / R = 1977/79 Light Jade.
You cannot go by repro parts sellers info, because most have no Ford truck parts catalogs...where this info is listed. Some of the info listed by repro parts sellers is guesswork.
If you want your VIN & Warranty Plate info decoded, post the whole tamale here....see *
There in no A/C code listed on Warranty Plates...or on the white Safety Standards Certification Label which is glued to the B pillar.
* Warranty Plate codes for 1976/79: VIN, W.B., COLOR, MODEL, BODY, TRANS, AXLE, YEAR, DSO.
Edit: The Warranty Plate in post #9 is similar, but does not have the year code or other jazz because it's from a 1974.
The 1973/79 Ford Light Truck Parts Catalog is available on a CD from hipoparts.com.
Old Mar 25, 2011 | 07:56 PM
D-mon's Avatar
D-mon
Yep the paint code is VR
I got the codes of the plate that is mounted off the cab not the door.
I do have the VIN number and have that figured out but just not the other numbers.
the truck is here right now so cant take a picture.
thanks guys
Old Mar 25, 2011 | 08:18 PM
NumberDummy
1963/80: The Warranty Plate is located on the left door face below rhe latch on US/Canadian assembled trucks.
The plate found on the cab is prolly a "Buck Tag" used by assembly line workers to assure the correct parts are installed on the assembly line according the vehicles specific build sheet.
There is no decoding info available for Buck Tags that I am aware of. Some of the info can be decoded because what is stamped on Buck Tags will be similar to what is stamped on Warranty Plates.
Some is gibberish, cannot be decoded.
Old Mar 25, 2011 | 08:57 PM
Melbatoast's Avatar
Melbatoast
gstirewalt
Feb 15, 2019 08:30 PM
jb1976miller
Mar 26, 2017 09:18 PM
fordtruckguy78
Aug 3, 2016 05:31 PM
MGannaway
Large Truck
Jan 23, 2014 11:09 AM
mfire138
Jul 27, 2011 06:29 PM
