Explorer Evaporative leak
Old Mar 24, 2011 | 12:53 PM
daveya48187's Avatar
daveya48187
Just got a code P0442 evaporative emission leak detected. the gas cap is not loose, what else can I check?
Old Mar 24, 2011 | 08:54 PM
shorod's Avatar
shorod
What model year is your Explorer? A few typical items that can cause this code, according to the 2002 Factory service manual, are:
  • Aftermarket EVAP hardware (such as fuel filler cap) non-conforming to required specifications
  • Small holes or cuts in fuel vapor hoses/tubes
  • Canister vent solenoid stays partially open on closed command
  • Damaged, cross-threaded or loosely installed fuel filler cap
  • Loose fuel vapor hose/tube connections to EVAP system components
  • EVAP system component seals leaking (EVAP canister purge valve, fuel tank pressure sensor, canister vent solenoid, fuel vapor control valve tube assembly or fuel vapor vent valve assembly)
-Rod
paul somlo
Escape & Escape Hybrid
Aug 4, 2015 12:59 PM
jrt2nd
May 27, 2013 08:50 AM
jerrylynnb
1983 - 2012 Ranger & B-Series
Oct 20, 2009 07:03 AM
Mornel
Aug 4, 2008 04:42 AM
84f250460
1997 - 2003 F150
Dec 4, 2006 05:57 AM
