Ranger Evaporator ?
Old Aug 3, 2008 | 12:56 PM
Mornel's Avatar
Mornel
Ranger Evaporator ?
The out put side of the evaporator (to condenser) has sprung a leak.
I'm in the process of removing the evaporator. The 1 1/8" nut connecting the top of the evaporator to the accumulator is rusted (frozen no pun intended).
Can this be heated with a tourch with out causing damage. Also does the accumulator have to be replaced because the system is considered open now. With the system open there should be no pressure issues, correct?
Old Aug 3, 2008 | 01:26 PM
Mornel's Avatar
Mornel
Please help !!
Old Aug 4, 2008 | 04:42 AM
lsrx101's Avatar
lsrx101
Yes, you should replace the accumulator. If you need to replace the evap also, just cut the tube.
You'll also need a new orifice tube.
Liemavick
Aug 29, 2015 12:37 PM
Ira Brown
Aug 10, 2015 04:40 PM
paul somlo
Escape & Escape Hybrid
Aug 4, 2015 12:59 PM
meck1
Aug 11, 2009 09:57 PM
Tim Ervin
Aug 26, 2005 02:36 AM
