well, i pulled off the bracket with the broken bolt and it turned out that when i drilled the bolt from the back side, it spun right out! guess i got lucky! thanks for all the help guys!!!!!!!
Basically, There several different types and brands. Depends on how much room you have on the piece that has the broken bolt. Distance to a water jacket etc. The Helicoil brand isn't bad and will do what most people want. They would work fine in this situation. They are inserts for high torque applications. I was in town getting some endmill bits today and saw some today that are supposed to be some bad dudes. These were expensive though.
Now, I am not a machinist. Yeh, I have a lathe,surface grinder and a milling machine. Old stuff picked up at auctions. My lathe is a 1937 model Lablond. My surface grinder is a 1942 model Brown and Sharp. There are tired but I have fun with them and don't have a 1000 dollars in them both.
I didn't even know there were different brands! I just thought Heli-coil was the name of a thread insert, didn't realize it was a company name. I guess I'm a....
Sounds like a VERY cool collection in your workshop!! I LOVE antiques, and seeing them work and still used is even cooler!
If the bracket is CAST IRON you can basically blow it out with a cutting torch since the torch can't cut cast iron.
Heat the bolt up just to the point that it gets dull red and "blow" it out with the oxygen stream. You can raise the heat to a little at a time if the dull red color isn't enough.
I would blow most of it out and then clean the rest out with a tap and or pick.
There is definitely a technique to this but it works.
Sounds like a VERY cool collection in your workshop!! I LOVE antiques, and seeing them work and still used is even cooler! _
Thats not a newbie issue. I learn things all the time and I have been at this for 25 years not counting the growing up years. Lots of cool things out there. That stuff catches my attention. I know I look like an idiot sometimes but who cares. One of the guys down at a machine supply store I go to has gotten used to me. I burn him up with questions. You know though it does help. I do this at lots of places because I am curious. I have built some good contacts over the years. Plus I always seem to get a discount on stuff or free stuff.
I like those old tools. I am not great at using them like a machinist is. You can get them pretty cheap at auctions. They are 3 phase so most people don't want to fool with them and they are heavy to move. Allot of times the moving expenses will be higher then the machines but I have paid for them several times over.
