engine control module
Old Mar 23, 2011 | 01:08 PM
AndrewDahlin's Avatar
AndrewDahlin
I have a 1983 F150 XL with a 302 Carborated engine, According to a Hannes manual there should be an engine control module somewhere in it, but I cant find it, the wiring diagram also shows the Ignition Module which is very easy to find. Is the ECM under the dash or do I even have one at all. also I do have a vacume line going to the advance on the distributor if that helps at all.
I hate Hannes books I hate them so much.
Old Mar 23, 2011 | 01:14 PM
Rogue_Wulff's Avatar
Rogue_Wulff
With a carbed 302, and DS2 ignition, it is doubtful there is any kind of ECU/ECM in the truck. Just for clarity, are there a lot of wires going to the carb? If not, then an ECU isn't needed.
Ignition module on the fender, got a blue plastic grommit where the wires come out? If so, more reason to doubt an ECU would be present.
breeves002
Computer Chips & Tuners
Apr 5, 2018 12:05 AM
ejaba
Jan 19, 2015 09:34 AM
F150Traveller
Dec 30, 2014 05:48 PM
xtal_01
Sep 13, 2014 12:42 AM
FORDTUF1
6.7L Power Stroke Diesel
22
Jul 29, 2014 07:25 PM
