2001 F250 Road Wander
Hey,
My dad has a 01 F250 with a little over 100k. Its got moto metal rims with the stock offset just 18 inch diameter. Stock tire size but BFG A/Ts.
The truck is horrible to drive any distance over 30 miles because you constantly have to pull the truck back to the center. If its going right and you bump it left a little it will keep going left and never seems to straighten out.
Is this a problem with these trucks, and if so, whats the cure?
You should have had it aligned when you replaced the Ball Joints. Have them rotate the tires Before you get it aligned as the front tires may have some strang wear on them by now.
Jfrei
40
05-02-2014 06:21 AM
