i did something wrong
Old Mar 22, 2011 | 09:48 PM
1bigjoe's Avatar
1bigjoe
i installed the ats turbo set up i got, in south jerzy
wow what an adventure.
heres my delima, there seems to be exhaust comming from some where near the snail. but it seem to be seated right
also the boost gauge, plactic tube line is tapped into the snail
but the gauge doesn't move, but if i take the line off and just blow into it ,the needle moves
all that being said the truck has a lot more get up & go
i guess it's all new to me ,
i have not turned up the fuel-----yet
what do you all think
Old Mar 22, 2011 | 10:05 PM
joe f350's Avatar
joe f350
to see bost u have to be driving not just reveing in ur drive way the gray smoke is blow by
Old Mar 22, 2011 | 11:04 PM
oreocreaming's Avatar
oreocreaming
you arent gonna get much boost until you turn that fuel up. you need the heat and air volume to spin it. the hotter it is, the faster it will spin. like joe said, until you start to lug it you wont really see anything. if you got a trailer, hook that baby loaded to it and see what happens. you do need to turn the fuel up though. 1 1/2-2 flats to start with. then you can fine tune it from there using the pyro after you get a few miles on it.
Old Mar 23, 2011 | 06:15 AM
Aune163rd's Avatar
Aune163rd
x3 on turning the fuel up. I turned mine up before I turbo'd it. Only a 1/2 flat...but after the turbo i ended up turning it up 1 more flat. My boost guage wasnt working until i did that. The snail leaking exhaust might be a sealing problem even if its seated correctly.
Old Mar 23, 2011 | 06:22 AM
Copedawg's Avatar
Copedawg
I had a exhaust problem after I installed a new Down Pipe. What I did was loosen the top clamp and roatated about an inch and tightened back up and it stopped.
Old Mar 23, 2011 | 08:09 AM
1bigjoe's Avatar
1bigjoe
well it sounds like the fuel has got to get turned up & thats- that
as i under stand when the ip is on the truck, &the allen key is in position, turning it towards the front of the truck clockwise is the way to go. i also read about a screw adjustment, on the pump, witch way do you turn that? any pictures?
whalebus2112
Dec 12, 2013 06:22 AM
Mercmeister
Jan 23, 2013 07:26 PM
79'F-250_Guy
19
Jun 16, 2012 09:53 AM
mblayton
1978 - 1996 Big Bronco
Aug 15, 2006 05:26 PM
Thudpucker
Feb 13, 2001 01:14 AM
