What do i have?
Old Mar 22, 2011 | 01:22 AM
HeeHaw78's Avatar
HeeHaw78
What do i have?
I am still learning alot about these and dont know what i have a rear end. this is supposedly a 78 f250 custom but not real sure. it has been thoroughly frankenstiened. also i think that the 4 inch lift on it was factory. in a few days when i get days off i am gonna try and find the vin on the frame and run it to see what it is if it dont match the vin on the cab. here are some pics
rear end
lift block
other side
Old Mar 22, 2011 | 01:33 AM
OrFordGuy's Avatar
OrFordGuy
those aren't lift blocks there the factory suspension... all the 4X4s came that way.. i likr to use them for lift kits however becuase of the factory u bolt girdles...the rear looks like a standard dana 60.. it should have a 44 or 60 front.. unless its a early 77 or even earlier it doesn't have a lift...sounds like a good truck anyhow
Old Mar 22, 2011 | 01:41 AM
HeeHaw78's Avatar
HeeHaw78
well a freind of mine has a factory 76 high boy and mine sets just as high as his does and we are both running 33s on them. so i was just curious. are the dana 60s good or not? not sure. i will get a pic of the front and post it so i know what i have for that as well thanks for the info OrFordGuy. i appreciate it. does it look to you like it could be a stock 78 suspension?
Old Mar 22, 2011 | 01:52 AM
OrFordGuy's Avatar
OrFordGuy
get me a freont pic and muesure your rear springs width for me.. if there 3" wide there 78-79.. the front will tell me what axle you have and if its a highnoy front...tyour buddy truck may be sagging or the body may be 76 but nothte frame... both trucks are 8 lug right????? and do either truck have a transfer case not connected to the trans????
Old Mar 22, 2011 | 01:59 AM
montana_highboy's Avatar
montana_highboy
Originally Posted by HeeHaw78
well a freind of mine has a factory 76 high boy and mine sets just as high as his does and we are both running 33s on them. so i was just curious.?
I see you have a 76/77 grille and positive arched front springs, do you have a divorced t-case? in cab fuel tank? crossmember under front bumper?
Old Mar 22, 2011 | 02:01 AM
HeeHaw78's Avatar
HeeHaw78
not sure about his ford, but yes i have a married transfer case and 8 lug wheels. i do believe the rear springs are 3inch wide. but i have leafs in the front to. so i am confused as i thought that most of them had coils in the front. but my springs are sagging some and need redone or replaced.
Old Mar 22, 2011 | 02:04 AM
HeeHaw78's Avatar
HeeHaw78
yeah the PO put that grill in it. but also the front fenders and doors and hood are from a 76. and the bed is from a 74 and the engine i think is from a 73 tbird but not sure. its a 429 and have no idea what it came from. t-case is married no in cab tank had duel tanks one big saddle tank on drivers side part under bed and part under cab, must be after market tank as its plastic. and the rear tank fit in between the frame rails. not sure about cross member under front bumper.
Would really love to find out exactly what i have and how to work with it. i can fix most anything mechanical if i can take it apart. but i dont have the knowledge or knowhow for alot of this s**t and it drives me nuts but i am trying to learn all i can.
Old Mar 22, 2011 | 06:49 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Hang in there HeeHaw78, you will figure it out with alot of FTE reading, and I mean A LOT! Or locate some FTE'ers in your state and have a G2G (get together)/BBQ.
Great way to learn first hand, when you get a bunch of Ford nuts in one place.
For the most part all F100/F150 1/2 ton (5 lug) 2wd and 4wd 73-79 Fords have a radius arm/coil spring front suspension. Reg cab and Crew cab (4 door).
And 73-79 F250/F350 8 lug 2wd same suspension as above.
73-79 F250/F350 8 lug 4x4 have a leaf spring front suspension.
Now for a odd ball, I believe if you have a super cab (nowadays it referred to most as a extended cab) it will have a 5 lug set up but with front leafs, and is called a "heavy half".
73 to 77.5 have 2 1/2" wide rear springs and a frame stiffener between the front frame horns that can be seen under the front bumper.
With your married xfer case and duel tanks, sounds like you have a 78/79 frame. Invest in a good set of manuals of CD's to help you out.
Even a Chilton or Hayes manual will get you going in the right direction, and you can get them at Advanced Auto for like 10 or 20 bucks?
All above info could be BS, and I am sure someone will let me know otherwise if I am wrong.
Old Mar 23, 2011 | 11:57 AM
HeeHaw78's Avatar
HeeHaw78
ok well i have looked and measured. i do not have crossmember under front bumper only front crossmember is underneath harmonic balancer. also my springs are in fact 3 inch wide. and here is a pic of my front end. not sure what it is.
thanks alot for all your help guys.
Old Mar 23, 2011 | 12:21 PM
78 PEB's Avatar
78 PEB
It's UMMMM greasy / dirty!!!! Seriously, If the bolt heads for the front cover on it are 1/2" its a D44 If they are 9/16" Its a D 60.
Old Mar 23, 2011 | 05:13 PM
77&79F250's Avatar
77&79F250
And measure the width straight across the end of the lock in/out 4" D60, 2 3/4 or 3??is a D44.
Scrape off the gunk on the bottom pumpkin webbing and look for a HD44 to the left of the cover as you are looking at it.
