distributor vacuum trouble
Old Mar 23, 2011 | 05:57 PM
ford_pickup's Avatar
ford_pickup
EGR valve should be enough, its best to go through the two port ported vacuum switch, use ported vacuum not manifold
Old Mar 24, 2011 | 06:55 AM
fordgarden's Avatar
fordgarden
Got it working now. Adjusted the ignition a little higher, and adjusted the carb to richer blending. still running without vacuum to the distributor. Butt it works fine. Planing to change this to one without duobble vacuum.
No more spark knock.
Old Mar 24, 2011 | 07:41 AM
ford_pickup
There is nothing wrong with the dual feed distributor, ported vacuum to the front manifold to the rear, will advance for power when you accelerate, will retard for emissions when you decelerate
Old Mar 24, 2011 | 09:20 AM
fordgarden's Avatar
fordgarden
I have tryed that, but then i get knocking. seems like the distr is sett to high in advansed vac. if i set the timing to 20" after topp dead center the knocking silence.
DonE911
15
May 30, 2016 03:28 PM
solo pilot
39
Jan 16, 2014 11:16 PM
Oldbone
May 7, 2012 04:05 PM
Superred2
Dec 15, 2010 11:43 AM
christcorp
Alternative Fuels, Hybrids & Mileage
Sep 28, 2008 03:37 PM
