Bronco II Ford Bronco II
Need some help???
Old Mar 16, 2003 | 08:19 PM
Bronco 1169's Avatar
Bronco 1169
Need some help???
I have a 94 Ford Ranger with a 4.0 v6 that we sold the transmisson for it then got a Bronco 11 1987 with a 2.9 auto the trans is shot so i have a manual trans from a bronco 11 87and the Computer and all that but?? But will the 87 manual transmisson Work with the 94 4.0 v6 and the computer work with the old trans if so what all would you have to do for it to work ??
and what all has to come with it ? Like should i do all of the wireing from the 4.0 and all it's stuff or what ? Please help?
Old Mar 16, 2003 | 10:00 PM
CustomChrome's Avatar
CustomChrome
Need some help???
The 4.0 will bolt right up to the 2.9 trans. You will just need to figure out what wires goto the neutral safty switch and the reverse lights. I'd use the 4.0 and the 4.0 harness and computer.
Old Mar 16, 2003 | 10:42 PM
bumpin_BII's Avatar
bumpin_BII
Need some help???
will a 3.8 bolt in easily with a clutch change? i need more topend but not more wheight so this is my q.
Old Mar 17, 2003 | 06:06 AM
CustomChrome
Need some help???
B-BII The trans is different. It will not bolt up. The swap to a 302 will only add 150-200lbs. So I dont think there is a weight issue there. You can get a little more top end in a 2.9 by adding roller rockers from a chevy but you will have to have the heads driled and tapped for studs. On the other hand the 4.0 motor rocks over the 2.9 and is almost the same motor so very little mods are needed in the swap. If your interested in doing one I can steer ya in the right directon on that.
Old Mar 17, 2003 | 05:43 PM
Bronco 1169
Need some help???
Well i have heared alot about the trans. But i have heard more that it will ? So if i ues the 4.0 all the wireing and neutral safty switch and the reverse lights too? But all of the wire's like the radio and light's will they just pulgin? or rewireing have to be done?
Old Mar 17, 2003 | 08:32 PM
CustomChrome
Need some help???
99% of all the wiring is the same. The only difference in the 2.9 and 4.0 harness is 3 wires. And they are for the cam and crank sencers.
deerhuntertyler
Jul 26, 2011 01:54 PM
budman325
Aug 19, 2009 05:13 PM
Notpilbrisk
1983 - 2012 Ranger & B-Series
62
Dec 13, 2005 09:48 PM
Bronco 1169
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Nov 26, 2005 02:18 PM
86scoot
Sep 7, 2002 11:56 AM
