390 keeps flooding need help
Old Apr 5, 2011 | 03:31 PM
  #31
NW 150's Avatar
NW 150
well I changed the filter and the distributor cap and rotor, and it runs fine now. There is a air bubble in the top of the clear filter that doesn't fluctuate now.
Idle still doesn't want to stay in one spot though as it moves around about 500rpm up or down.
Old Apr 7, 2011 | 11:34 PM
  #32
LxMan1's Avatar
LxMan1
Does your truck use a throttle cable or a solid rod. I had to adjust the rod on my 63 because it would sometimes pull the throttle open a little as the engine moved around which is normal. I had to lengthen mine a little.
Old Apr 8, 2011 | 10:11 AM
  #33
NW 150's Avatar
NW 150
I believe it's a rod. I'll have a look see at some point in time. I have the carb off now and will take it to a shop soon enough.
Old Apr 10, 2011 | 01:09 AM
  #34
LxMan1's Avatar
LxMan1
As for the idle fluctuation, try running it and revving it up some with the rod unhooked and see if it still jumps around.
Old Apr 10, 2011 | 07:52 AM
  #35
NW 150's Avatar
NW 150
will do. i'm taking the carb in on wednesday and should have it back by friday from what the guy told me. Once I get it back i'll put it back on and mess around with it.
Old Apr 10, 2011 | 03:18 PM
  #36
LxMan1's Avatar
LxMan1
Good luck.
Old Apr 21, 2011 | 08:09 PM
  #37
NW 150's Avatar
NW 150
well after taking it to the shop, the results were not much was needed to be done. The guy said he cleaned everything out and adjusted the floats. I put the carb back on and what do ya know, it takes off better, puts you back in the seat a little more when you punch it a bit, and revs faster when all four are opened up.
Old Apr 22, 2011 | 12:10 AM
  #38
LxMan1's Avatar
LxMan1
That's good to hear. Thanks for the update.
BigCountry1978
Jul 8, 2016 04:51 PM
topmoo
Jun 17, 2015 06:19 AM
walkaree
May 7, 2015 12:44 AM
swolh
27
Feb 8, 2015 10:45 AM
Jfitzgerald
15
Oct 23, 2014 08:07 AM
