Aerostar Ford Aerostar
'95 4.0 Vacuum modulator oddity
Old Mar 20, 2011 | 08:32 PM
Two99Point80's Avatar
Two99Point80
My '95 Aerostar 4.0 no longer likes to shift out of first gear. It will if I accelerate to maybe 25mph and completely get off the throttle for a few seconds. (It also revs freely at full-throttle kickdown, as though it was in neutral.) A fluid and filter change didn't help, so I dug into forum posts. I found the vacuum modulator, and there's no ATF in the vacuum line, but it's an adjustable one which has me baffled...
The modulator has a thumbwheel on the outside of it. It will unscrew completely - and then it comes off, with a pin attached to it. This is very different from the ones I've seen pictures of here, where the pin is moved by the diaphragm. Is this the same pin, or some kind of preload device for the actual pin farther inside?
There's enough else wrong with the Aerostar that I'm not willing to sink very much more money into it. It'll run as is, as long as I'm careful. I'm just trying to get a few more miles out of it... might a regular, non-adjustable modulator help?
Thanks!
Old Mar 20, 2011 | 10:12 PM
The_Ford_Driver's Avatar
The_Ford_Driver
this link may help...
https://www.ford-trucks.com/forums/8...irst-gear.html
Old Mar 21, 2011 | 07:56 AM
Two99Point80
Originally Posted by The_Ford_Driver
Thanks for that! The last post in that thread - about throwing the transmission into Park at 25mph - sure got my eyes wide open, even at 6AM on a Monday
If nothing else comes along, I may try backing up slowly and shifting into Drive while still moving. Many drivers do that kind of thing regularly, so it shouldn't leave the tranny in the road, and doing it a few times might help. Hey, people used to bang on their TV sets all the time...
EDIT: Replaced the vacuum modulator but no change in symptoms.
Last edited by Two99Point80; Mar 22, 2011 at 12:14 PM. Reason: modulator replacement
jim33067
Aerostar
Sep 8, 2016 03:59 PM
sony420
16
Jun 15, 2015 10:05 PM
79F-1504x4
May 28, 2010 09:39 PM
ieatcamaros
Nov 25, 2005 07:41 PM
bct
Dec 30, 2004 04:22 PM
