help with decoding cel codes on 95 explorer
Old Mar 20, 2011 | 07:52 PM
rickthefix's Avatar
rickthefix
i took a video of the light flashing on the 95 explorer i was asked to work on. the flash sequence does not make sense to me. can you guys take a view & let me know what the codes are? TIA
95 Explorer CEL :: VID_20110320_193941.mp4 video by Rickthefix - Photobucket
or
Old Mar 20, 2011 | 11:35 PM
mrshorty's Avatar
mrshorty
It looks to me (assuming the video played right, sometimes I miss a flash because the video doesn't play smoothly) like you have KOEO/CM 113 (KOEO and CM are separated by the separator pulse at about the 35th second). KOEO 113 points to a fault in the IAT circuit. 1st thing to do would be to make sure the IAT is plugged in. IAT is a simple thermistor so it is easy to test with an ohmmeter.
Old Mar 21, 2011 | 06:37 PM
aquanaut20's Avatar
aquanaut20
<table align="center" border="1" width="87%"><tbody><tr><td>
113
</td> <td>
(O,M)
</td> <td>
IAT sensor is/was high or open - IAT
</td></tr></tbody></table>
The thermister is in the intake tube between the MAF and the Throttle body.
Check the wiring and connector for breaks and bad connection, and the AIT with a DVOM....
Old Mar 21, 2011 | 07:47 PM
rickthefix's Avatar
rickthefix
yeah, i know all about this code, fought it with my 87 F150, ended up buying one from NAPA, the cheap ones at the zone & advance even new were out of tolerance
danskool
May 6, 2012 01:05 PM
diablodude64
Feb 25, 2012 10:32 PM
Sickler1
Dec 18, 2011 06:47 AM
ManicMike
Nov 16, 2011 04:43 PM
