460 piston orientation
Old 03-19-2011, 05:15 PM
CaptainIPSC's Avatar
CaptainIPSC
CaptainIPSC is offline
I'm putting together my short block ( heads are still in the shop ). I'm installing Keith Black Hypereutectic Pistons with a 33cc dish. The piston don't have the notch denoting front of engine. I "think" the flat portion goes towards the intake ( inside ) and the dish towards the exhaust ( outside ). Am I correct?
Old 03-19-2011, 09:52 PM
jwtimme's Avatar
jwtimme
jwtimme is offline
are there any valve reliefs in the pistons or only a dish.
Old 03-19-2011, 09:58 PM
CaptainIPSC
There's a pretty small cut that might be considered a valve relief cut in one corner of the dish if that makes sense.
Old 03-20-2011, 09:43 AM
OldRacerGuy's Avatar
OldRacerGuy
OldRacerGuy is offline
I'm assuming your KB pistons have a d-shaped dish, just look at the heads and match the quench pads (the flat part) with the pistons. I other words, the dish in the pistons reflects the combustion chamber.
Old 03-20-2011, 10:02 AM
CaptainIPSC
I would but my heads are still in the shop.
Old 03-26-2011, 10:03 AM
mark a.'s Avatar
mark a.
mark a. is offline
If there is a valve relief cut in the piston it will be for the intake valve.
Old 03-26-2011, 02:41 PM
OldRacerGuy
CarsByCarl
Scroll down a bit, all engines with dish pistons have the dish to the exhaust side and the quench pads (flats) to the center.
Old 03-26-2011, 08:37 PM
CaptainIPSC
Thanks guys. I was looking for the info last weekend and got on here and dug around and found a similar sight to the one OldRacerGuy linked to. Found what I needed and got everything together. Now if my Carb and Heads would hurry and show up I'd be golden!!!!! Thanks again!!
sybersmith
Projects
01-22-2011 07:56 PM
monkei
15
04-17-2010 09:38 AM
1963f100
05-09-2007 03:50 AM
broncman
08-04-2006 01:57 PM
werkdatool
03-17-2004 03:12 AM
Quick Reply: 460 piston orientation
