Gonna be tackling a 1991 E40D flush tomorrow. This article Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles says to have a length of clear tubing available to clamp over the tranny cooler return line. Can anybody give me a close approximation to the size of the return line nut so I can get the right size tubing? Thanks!
I have never done it but I would think you should be able to slide the pipe nut back on the pipe and push the plastic tubing over the pipe. So, I would think, you would need something around the dia. of the cooler pipe.
Just my guess.
That will work. Either way, I was just hoping someone could give me an approximate size so that I wouldn't have to read a tape measure. I know how to read one, I'm just lazy.
Isn't there some catastrophic possibility
with some sort of flush trick that is
never recommended?
Back flush? maybe?
Just drain, try to drain the torque converter too>?
there are 2 different filters so get both and
HOW much ATF?
Pls let me know how that trans cooler line idea works.
Thanks
Sorry I couldn't get to it today. I was going to but I had a couple other things to do first and by the time I was finished with them, I didn't have time.
As for the "catastrophic possibility" and "back flush," I don't know what you're talking about.
I'm sure the method outlined in that link will work properly- it makes sense when you consider that the tranny will be circulating the fluid and doing the work. I'm sure I have the right filter too.
I plan on taking it on next weekend so when it's done I'll let you know how it worked out.
I used that procedure on my last '93 Lightning. IIRC I used 5/16 or 3/8" tubing. It has to be large enough to get over the flare on the end of the cooler line, not the nut. It took about 16 -18 quarts to do a complete flush/fill.
I just called a local shop and for 100 bucks they'll hook it up to some machine, 'backflush' out the old oil as new oil goes in.
Apparently this break loose sediments by running fluids backwards somehow that are happy where they are (if the trans works ok)
and will cause more trouble than you could ever want.
My other local trans guy said to never do that.
do it the old fashioned way, get under there, drain it and the TQ if you can, get dripped on and messy and put in a new filter, of which, there may be 2 dofferent ones so get them both and return the one that doesn't fit.
He refuses to do them personally, so I know he's not trying to sell me something.
And I was reading thru the procedure here at home, trying to familiarize myself with it, and I was getting confused. It says the system holds 18 quarts total, but then at one point it sounded like I was going to be flushing 19 quarts all the way thru. I just checked and it's step 5 that I'm talking about, but maybe this is to bleed air out of the system? I'm just trying to be clear on this step as I bought $50 worth of tranny fluid for this and I don't want to just waste it, y'know?
drjoe , As you were told there are two school's of thought by two Trans Shops. But this was my experience. I did the Trans backflush on a C6. Three days later, I went out one morning and my concrete driveway looked like a mass murder with fresh red ATF running down the driveway . The Trans shop said that the backflush and new ATF cleaned up some seals that had been sealed with dirt or sludge and now they were leaking . It turned out to be the front pump seal,which they would replace for cost. But down the road I believed if one seal was now leaking that another one was on the way, I just got them to rebuild it. They discounted the normal cost. It's your choice, But for me, I'll just drain the TQ, Pan and change the filter from now on. I have done 2 more that way with no problems. Just my 2cents. Best to Ya '92
