a friend brought a 04 F250 to the shop that had quit on him, i tried and after several attemps it finally started running but u couldnt drive it because when u gave it throttle it would hardly go or just cut off.. here are all the codes it spit out btw i unplugged the MAF to get it to crank P0113 -P0270-P0278-P0460-P1102-P2269-P2291-U0155 IT ALSO SAID IT WASNT COMMUNICATING with the Dashboard Any helpful tips would be Greatly Appreciated.. Thanks Danny D
thats very low. what filters are you using. are they new filters. replace the regulator spring. odds are though thats not gonna to fix your main issue.
ok new filters and he went ahead and got a new fuel pump(under warranty) he has connections at the parts store: fuel pressure is back up and working good, found alot of water in the fuel so i drained as much as possible and put in fresh fuel and load tested the batts and had to replace the pass side batt and still not running
