Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
engine change out
Old Mar 19, 2011 | 02:46 PM
mo1948f1's Avatar
mo1948f1
engine change out
Hey Everyone, I have to change out the 292 y block in my 63 f600 and. have a 400 out of my 79 f350 with a t18 ,,beside the different engine mounts and tranny cross member will i be able to bolt the t98 up to my 79 bell housing to keep the trans brake on the truck? the 292 threw a rod out the side of block going about 50 down the hiway,, really blew my day , but want to put the 400 in it out of my 79 f350 then scrap rest of 79 ,Or is there a better engine that would work,, I already have the 400 and it runs good rest of truck is rough, but it runs good Thanks Randy
Old Mar 19, 2011 | 06:26 PM
85e150's Avatar
85e150
I'm thinking your T98 has the older "square" trans-to-bell pattern, while the '79 bell will be drilled for the Ford "butterfly" pattern.
You can see the patterns in the pics here:
Toploader Imposters
The 2nd pic down, where they say "4 vs. 8" holes--looks like 4 vs. 6 to me.
More on both, and you can see some pics and they also give dimensions of the pattern:
The Borg-Warner T18 & T19 Transmissions - Novak Conversions
Old Mar 28, 2011 | 08:44 PM
mo1948f1's Avatar
mo1948f1
ok guys another question, i found a 330ft and tranny out of a 73 f600 with a front mount and a bell housing mount set up ,will it bolt in place of my 292 ? or will i have to change cross members?
Old Mar 30, 2011 | 08:50 AM
80broncoman's Avatar
80broncoman
I'd go for the more moderen engine mayself. and I'd use the trans that is on it also. you can adapt a trans brake to to almost and trans that has a fixed yoke. Although you may need to make a bracket or something. I've seen a few fork lift disc brakes on a trans for a parking brake.
mgerdau
May 11, 2014 01:05 PM
JLmissouri
Dec 7, 2013 12:42 PM
scott78f2504x4
Oct 11, 2010 01:19 PM
havi
May 10, 2008 03:44 AM
mcrank
Jun 3, 2002 07:40 AM
