So when I merged on the highway i reved it kinda high and my alt light came on and stayed on. I tryed turning off my truck and start it back up and nothing. Not sure what to do next. I was able to drive home about 10miles with no problems.
Check voltage at the battery when the truck is running with an ammeter, should be around 14.6 if its lower you have a charing system problem. Most likely bad regulator or alternator.
Use a voltmeter, not an ammeter. A voltmeter measures voltage; an ammeter measures current.
