Intake gasket replacement
Old Mar 18, 2011 | 09:10 AM
kentuckyredneck's Avatar
kentuckyredneck
I'm replacing my intake gasket this weekend. I don't have a Haynes manual. Can someone who has one look and see if there are specific torque numbers for the intake, or if I just tighten the bolts to where I like it. Thanks.
Old Mar 18, 2011 | 09:55 AM
DBGrif91's Avatar
DBGrif91
My Chiltons reads 23-25 ft.-lbs. And remember to start in the middle and work your way outward in a "circular" or "spiral" pattern. Also make sure to run the sequence at least 3 times- tightening one bolt can loosen the bolt next to it. Ideally by the 3rd time you will be getting the proper torque reading [or a click if you have that type of wrench] immediately.
PS I'm assuming you meant the truck in your sig, so that's what I posted for.
Old Mar 18, 2011 | 01:14 PM
kentuckyredneck
Thanks. Yeah, the truck in the sig. It's looking more like I need to buy a Haynes or Chiltons...
Old Mar 18, 2011 | 08:17 PM
kentuckyredneck
Ok, another question. How do I get past the fuel rail? I'm guessing I take it off. What tool takes the lines off, and how do I get the injectors out/off? This is a major hang-up in the project.
Old Mar 18, 2011 | 09:41 PM
zxwut?'s Avatar
zxwut?
Go buy a manual and it will all be simple. Trust me.
Old Mar 19, 2011 | 01:34 AM
ExtrmZ's Avatar
ExtrmZ
not necessarily. those haynes manuals never seem to have the information you need. Do some research online, someone has posted a good manual somewhere on here. you just gotta find it
Old Mar 19, 2011 | 03:26 AM
Silvereagle's Avatar
Silvereagle
Trailering
There are a couple of ways to go. U defintly need to torque the intake bolts correctly anda t the right torque as far as the manuels I myself never have liked haynes manuels never detailed enough there saying is if this isnt enough info then u need to take it to a professional mechanic. If u can purchase a Chilton manual then do it. They have all the complete steps and torque specs. They are also a lot more detailed. If u cant purchase a manual then the next step I would do is go your local libary and have them copy the section needed. Also u possibly could purchase a online manual and then print pages as u need them which makes it nice so U always have a clean and legiable manual.
Old Mar 19, 2011 | 06:18 AM
DBGrif91's Avatar
DBGrif91
The fuel rail isn't difficult. First make sure the pressure is bled off.
You will need a fuel line disconnect tool- see below links for two possible options. Be aware that the springs can be "seized" to a point so they might not break off right away. I found light tapping on my disconnect tool with a pair of pliers did the trick after giving some PB blaster a few minutes to soak.
Once the lines are off, there's 4 bolts- 2 to each side- to be removed. Once those are out, the fuel rail should basically just lift off. I can't remember if the injectors will come with it or not- doesn't much matter. The injectors really aren't that tight of a fit into the manifold- they're good and snug, that's about it. I would recommend new o-rings for them tho, when you're ready to reinstall.
http://www.oreillyauto.com/site/c/de...0044&ppt=C0052
Old Mar 19, 2011 | 08:27 AM
kentuckyredneck
Wilmar W83148 - Disconnect Tool | O'Reilly Auto Parts
OTC 7660 - Spg Loc Tool | O'Reilly Auto Parts
Thanks so much!
