arp stud instructions
Old Mar 17, 2011 | 07:29 PM
rdunagan's Avatar
rdunagan
anyone have instructions for the studs. mine didnt come with the sheet in the box for some reason. thanks!
Old Mar 17, 2011 | 08:39 PM
2006powerstroke90's Avatar
2006powerstroke90
What I did.
Put a decent amount of the arp lube that comes with the studs.
Put them only in hand tight the directions seemed to make sure they were really only hand tight. I used a Allen key just tightened them down snugly.
Then put the heads on, I did the push rods then rocker arms, torque the 10mm rocker arm bolts first.
Then I lubed the studs again put the washers on then nuts.
Did 75/150/210 from the first 2 in the middle out.
I would a generous amount of lube.
Old Mar 17, 2011 | 10:26 PM
Fallguy2004's Avatar
Fallguy2004
^^^ That should work just fine. But remember to lube the washers on both sides as well, some folks forget the washers need lube too!
Old Mar 17, 2011 | 11:00 PM
hubler13f's Avatar
hubler13f
Here you go!
Remember depending on what lube your kit came with your final torque may vary. With the new Ultra lube final torque was 210 ft lbs, With the old moly lube it was like 245 ft lbs. But I'm sure all the old kits with the old lube have been run through and or updated.
Old Mar 17, 2011 | 11:17 PM
rdunagan's Avatar
rdunagan
all 3 of yall are life savers!! thanks i really didnt wanna have to call and wait on hold or search forever! and yea it came with ultra lube and mkm customs sent me another bigger tube of extra lube i think
Old Mar 18, 2011 | 11:29 AM
Zmann's Avatar
Zmann
here is a printable version
http://arpdiesel.com/Instructions/250-4202.pdf
d-day
32
Mar 28, 2015 06:07 PM
Royson12
68
Sep 30, 2012 11:13 AM
jlo84truck
Jul 15, 2010 06:58 PM
DSMMH
Jul 10, 2010 08:11 AM
UGA33
Feb 10, 2009 03:17 PM
