Don't know what else to do
Old Mar 19, 2011 | 08:57 PM
  #31
99StrokeXLT's Avatar
99StrokeXLT
ok cool. then you just slide the center support off, replace with new, and slide it all back together...?
Old Mar 19, 2011 | 11:26 PM
  #32
wydomkr's Avatar
wydomkr
I believe that this is built the same way that all of the others I have done. Pull out the drive shaft (both parts and carrier) out from under the vehicle. It is much easier to fix out from under the truck. It will pull apart, the male and female splined shaft. Slide off the carrier bearing, and reinstall. Best of luck. This is probably the least expensive fix of the options that could be wrong. It could be in the rear end, pinion bearing or axle bearings. These are more expensive.
Good luck!
Old Mar 20, 2011 | 08:43 AM
  #33
99StrokeXLT
Thanks again, I'll try this fix when I get the EGR tube and sensor this week...we'll see if anything changes
Old May 26, 2016 | 10:40 PM
  #34
Alzito Florida's Avatar
Alzito Florida
Originally Posted by 99StrokeXLT
How do you get the center support bearing onto the front half of the two piece rear drive shaft? I know there is a nut on the rear facing side of the front half of the rear driveshaft shaft, aft of the center support bearing, that is exposed when you separate the two halves of the rear shaft. Does this separate the front half of the rear drive shaft into two pieces? so that you can slip in/out the center support bearing?
the picture below show where the front and rear halves of the rear drive shaft meet. I am referring to the arm that is between the u-joints and the center support bearing.
So. Did you find a way to separate it? I have the same prblem on my 2011 and I have no idea hwo to separate these two parts or even where to buy the center support for 2011. But it is in bad shape and it's vibrating a lot
Old May 26, 2016 | 10:55 PM
  #35
Rikster-7700's Avatar
Rikster-7700
The center support or carrier bearing should be at least available at your local dealership? You may be waiting a while for an answer from the OP, this thread is 5 years old and I don't recall seeing the OP around these parts of late.
Old May 27, 2016 | 05:17 AM
  #36
hammer65's Avatar
hammer65
On my 2011, Screw, They replaced the whole drive shaft, because the center bearing was thought to be causing the vibration I have. There is a TSB on Center Bearings, going bad. 60,000 mile power train warranty will cover it.
FTreeFidd
Jan 2, 2018 02:12 PM
Grease & Gravel
1983 - 2012 Ranger & B-Series
Mar 24, 2017 09:42 PM
blwn350
Mar 2, 2017 11:50 AM
Heavy_metal-2000
General Automotive Discussion
Jun 28, 2016 09:35 AM
chipper
Jun 5, 2016 11:01 AM
