O/D OFF switch doesnt work
Old Mar 17, 2011 | 09:18 AM
Evilution's Avatar
Evilution
not sure if the fuse is blown or if the switch itself is bad. the only reason I really care is I dont want it shifting into OD at the track. is there a way to manually keep it out of OD with a broken switch? what fuse is it anyway?
thanks again,
marty
btw truck is a 96
Old Mar 17, 2011 | 09:31 AM
lew52's Avatar
lew52
I don't know , but every time you shut the truck off it goes back to OD , you need to press the button , the light should come on , then OD is off till you press the button or shut the truck off....Lew
Old Mar 17, 2011 | 09:33 AM
rla2005's Avatar
rla2005
Here is a schematic of the E4OD control circuit:
The Transmission Control Switch is the button on the end of the shifter lever.
Old Mar 17, 2011 | 09:42 AM
Evilution's Avatar
Evilution
ya i figured that was the case like in my old 02 mustang but when i hit the button... nothing happens, no light, no dropping out of OD nothing. guess something has got to be messed up in the wiring.
Old Mar 17, 2011 | 10:00 AM
1965F100's Avatar
1965F100
I have seen more than a few times this wire get frayed in the column, it is often accompanied by fuse popping as well.
Old Mar 17, 2011 | 10:32 AM
lew52's Avatar
lew52
I took mine out of the column and put it on the dash , and removed the shifter , and put it on the floor where it belongs....Lew
Old Mar 17, 2011 | 11:23 AM
rla2005's Avatar
rla2005
Lew:
Old Mar 17, 2011 | 12:34 PM
lew52's Avatar
lew52
Ha Ha thats cool !! i remember them , yeah i don't care much for column shifters , then when they get loose i hate them ....
Old Mar 17, 2011 | 03:13 PM
Evilution's Avatar
Evilution
what shifter did you use? I miss my B&M pro ratchet.
Old Mar 17, 2011 | 03:33 PM
lew52's Avatar
lew52
I use the B&M pro stick , i like gate shifters , i had a mount made for it....
Old Mar 17, 2011 | 10:33 PM
Evilution's Avatar
Evilution
that doesnt sound like a bad idea. did you use the AOD kit? your running a 4r70w right? did you use a manual VB or a full manual shift kit?
Old Mar 18, 2011 | 05:22 AM
lew52's Avatar
lew52
Yeah im running a 4R70W with a B&M street /strip shift kit , still auto , had a comuter tune so i don't have the factory rev limiter , i can control the shifts manualy , or if i leave it in drive , the shift point is set at 5800 at WOT , if you do a shifter you will need the AOD kit....
Dirtfarmer69
Nov 5, 2014 06:34 AM
chuck1058
Oct 19, 2014 04:22 PM
clouden
Sep 2, 2010 09:21 PM
Dirtfarmer69
Sep 3, 2007 01:26 PM
