if you didn't go to bike week , you didn't miss anything----cold- 40* at night
so the last time i was here
i bought a 1993 7.3 motor with a turbo setup attached.3in dp two full day's later it is installed
got a 10 foot lenth of 3in exhaust pipe,
had the meinike shop bend a 90* elbo, & 2- -45* elbos , cut a hole in the bed, & up she went!!!!
coated the whole thing with under coat paint---done.
the pyro gauge is working fine.
but the boost gauge is not ithink there is a problem with the tube ,i had to couple two tubes together i can't find one piece long enough
what did you use??????????
