77 ford f100 lookin into powerstroke swap
Old Mar 16, 2011 | 01:04 AM
CRUNKED77FORD's Avatar
CRUNKED77FORD
ok i got a built 400 in my 77 ford f100 shortwide. the more an more i see bout powerstrokes the more i want to do a swap. i was wondering just rought estimates what a good used powerstroke with computer etc would set me back. then is the auto or a zf 5 or 6 speed best an on average what it will set me back. an if my 8.8 rearend with 3.50's an a trok lok that i swapped outta my old 87 will handle it? just any ideas. also what is the best powerstroke as far as performance vs price?
Old Mar 16, 2011 | 09:42 AM
Kemicalburns's Avatar
Kemicalburns
figure going to 1 ton drivetrain plain and simple. also that F100 frame will need boxed to keep from twisting. I would then get a wrecked truck that has the motor/trans setup you wish to use. if you dont know how to weld figure the cost to increase substantially. I have many friends that have done CTD swaps into there 70's fords and with the motor and trans along with fab work it ran about $5K.
is your F100 2wd or 4wd?
Old Mar 16, 2011 | 03:16 PM
CRUNKED77FORD
mine is a 77 ford f100 shortwide 2wd. i can weld but it looks like a 5 yr old did it. as far as cummins an powerstroke which diesel is the cheapest with best performance. i got the mind set to build a hot rod f100 like i got but with a diesel powerplant. 5k is do able the 460 i planned to build the build sheet for it was bout 4500.
Old Mar 16, 2011 | 04:36 PM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
I would start with a 3/4 or 1 ton chassis. Perferabley 1 ton just to save the work of chassis up-grades.
Beyond that I do not know much about diesels.
Old Mar 16, 2011 | 05:44 PM
Kemicalburns
i think cost depends on how cheap the donor rig is itself. I know the Cummins doesnt need to much wiring to get running vs the Powerstroke being more involved.
Old Mar 16, 2011 | 11:41 PM
Ziegelsteinfaust
I have found 1 tons for less then $500 not running, and running ones for about a $1000.
Either one saves tons of work, and won't need to many mods to hold up to diesel power/weight.
If he does a 4bt swap like CarCrafter then a F100 with his 8.8 would be resonably durable if he is easy on the clutch.
I like the guy above would angle towards a 12V Cummins since they are the simplest to hook up.
I am interested in a diesel swap, but I would probily swap in a mild 302 and a turbo to gain my mpgs up.
Old Mar 17, 2011 | 08:50 PM
CRUNKED77FORD
i just want massive torque. i had a 302 that was built up. 9:1 d0oe heads bmll cam etc it was ok. this 9.5:1 400 is awesome but i want more. i what a 4bt? a 4 cylinder diesel? i got some new mufflers an exhaust put on. jones full boars with 3" dumps over axle sounds decent'
christiansill5509
Feb 6, 2017 10:00 PM
f100kilgore
Jun 26, 2016 07:50 PM
towsrus
27
Oct 29, 2015 09:08 PM
Ronnie Basil Smith
Oct 8, 2015 01:52 AM
the_auto_tech
Jan 7, 2014 06:09 AM
