I need a front cover.
Old Mar 21, 2011 | 07:55 PM
bad12jr's Avatar
bad12jr
It's complete minus the alternator, water pump and ac compressor.
Old Mar 21, 2011 | 08:02 PM
F350-6's Avatar
F350-6
Sounds like a deal. Don't forget to check for a dusted turbo, or if compression seems low, see what happens if you add a few drops of oil in the low cylinder and test again. And of course, jumper cables.
Old Mar 21, 2011 | 08:53 PM
bad12jr's Avatar
bad12jr
Will do. I'm thinking about just doing a rebuild and sticking my uppipes and charger on it. Change the tuning and run it.
Old Mar 21, 2011 | 09:08 PM
F350-6's Avatar
F350-6
I don't know what turbo you have, but I'd consider sticking with the SD set up and installing the SD bellowed up pipes. Much cheaper and you'll never have a boost leak there again.
Old Mar 21, 2011 | 11:12 PM
bad12jr's Avatar
bad12jr
I was gonna put the OBS charger on. I'm going to build a t4 mount this fall/winter so it's not gonna be on long. I'd love to just drop this motor in. So I might run the SD turbo. But I wanna figure out why he pulled it first.
Sorry this is the only truck I could get
PRexcursion
Nov 18, 2011 06:53 AM
1978fordf250
Sep 7, 2010 09:52 PM
stf26
6.7L Power Stroke Diesel
Aug 19, 2010 10:27 PM
pcwirepro
Feb 18, 2003 05:11 PM
